Changing a port from a vlan to another
Answered Question
Apr 19th, 2012
Hi everyone,
I have a 3560 switch with the following ports config
interface FastEthernet0/43
description : Link to PC + ShoreTel IP Phone
switchport access vlan 120
switchport trunk native vlan 120
switchport mode access
service-policy input VOICE
interface FastEthernet0/25
switchport mode trunk
interface FastEthernet0/28
interface FastEthernet0/46
I would like to use theses ports on a different vlan to connect 4 pc's to them. Can I just remove them from the vlan, remove the trunk switchport and set up on the vlan i want them on with no trunking?
Wilfredo
Correct Answer by burleyman about 5 years 1 month ago
Here is how I do it when I re-provision ports
This part sets the interfaces to default config.
config t
default int fa0/43
default int fa0/25
default int fa0/28
default int fa0/46
Now you can configure the ports
interface faX/X  <---- substitute the X/X with the port number
description PC
switchport
switchport access vlan XXX  <------ substitute the XXX with the Vlan you want to assign
spanning-tree portfast
no shut
then save the configuration by issuing the command     write mem
Hope this helps.
Mike
Correct Answer by glen.grant about 5 years 1 month ago
  Quick answer is yes.  Just do the following for each port
conf t
default interface Fx/x
interf fx/x
switchport
switchport host
Overall Rating: 5 (2 ratings)
Correct Answer
glen.grant Thu, 04/19/2012 - 08:41
  • Purple, 4500 points or more
conf t
interf fx/x
switchport
switchport host
waguilar71 Thu, 04/19/2012 - 08:46
Thanks for your reply Grant, what do you mean by default interface
glen.grant Thu, 04/19/2012 - 08:59
Default interface fx/x will set that port back to factory defaults without having to do a "no" command for each line in the port config.
Correct Answer
burleyman Thu, 04/19/2012 - 08:48
  • Blue, 1500 points or more
config t
default int fa0/43
default int fa0/25
default int fa0/28
default int fa0/46
description PC
switchport
no shut
Hope this helps.
Mike
waguilar71 Thu, 04/19/2012 - 09:47
Thanks guys,
The instructions worked that both of you provided. One more detailed than the other but they worked. I did use the command
spanning-tree host and it setup the port at portfast by default. I will be making the connections tonight of the pc's and all should be well.
Wilfredo
