ASA5505 Security Bundle
Apr 19th, 2012
On the ASA5505's, is it possible to get the features of the Security Bundle on a user count less than unlimited. Basiclly I'd like a 25 or 50 user ASA with the ability to have an inside, outside and DMZ
I'm pretty sure units without the Security Bundle only allow for 2 VLANs.
codewize Fri, 04/20/2012 - 08:52
OK now that doc says that the base license provides 3 VLANs. 2 normal and 1 restricted. What does that mean? Again my goar is to have inside, outside and a DMZ for public Wi-Fi
Can I do that with the base license?
Lee Kendrick Fri, 08/10/2012 - 16:45
My understanding of this is that you can have 2 normal Vlans (inside and outside) and these you can configure to pass traffic between the interfaces. The restricted Vlan allows you to connect to the DMZ from the outside, but prevents you from being able to pass traffic from the DMZ to the inside.
2.5 Vlans - not great.
Login or Register to take actions
Posted April 19, 2012 at 9:38 AM
Updated August 12, 2014 at 1:29 AM
Stats:
Replies:3 Overall Rating:
Views:1009 Votes:0
Shares:0
Tags: No tags.
