Warning message
Cisco ASA 5520 8.3 w/ ASDM 6.4 Filter VPN Traffic to certain subnets
Apr 19th, 2012
I am trying to find documentation on filtering VPN traffic on a Cisco ASA 5520.  I have found limited documentation that seems to be more related to older versions or even "PIX" devices that doesn't seem to match up with what I have.  Basically I have 2 vendors that would like VPN access into my network for easier access to their devices.  Each Vendor has a specific Vlan they are assigned to so I wanted to just give them full access to that address range and nothing else.  Any help would be greatly appreciated.
Julio Carvajal Thu, 04/19/2012 - 13:49
  • Purple, 4500 points or more
What kind of VPN are you going to use: Site to Site, remote access Ipsec or anyconnect?
Julio
gregorysieg Fri, 04/20/2012 - 04:54
Yes sorry, I am trying to setup a remote access session, most likely SSL/Anyconnect.
Jouni Forss Fri, 04/20/2012 - 05:11
Theres atleast 3 ways to do what you are trying to achieve.
  • You can use split-tunneling to define the networks visible/usable for the remote user in the group-policy of the VPN connections.
  • You can use a VPN filter access-list to define what traffic you want to allow to the mentioned networks (if you dont want to allow all traffic)
  • You can make the ASA behave so that all connections coming from OUTSIDE interface will be checked against the OUTSIDE interface access-list (Even the VPN Client or L2L VPN connections). Personally I like to use this option
Do you have any existing VPN connections on the ASA at  the moment?
I dont have a link to the documentation at the moment, though I think I could find you one. I can also give you example configurations if you need.
- Jouni
