Moving Identity certificate from one ASA to another
Apr 19th, 2012
I'm trying to export identity certificates from an ASA 5510 to 5520, I'm exporting in pkcs12 format and specifying a passphrase. When attempting to import to the 5520, I get "error import pkcs12 operation failed" from cli or asdm.
Marcin Latosiewicz Fri, 04/20/2012 - 00:04
You should check if you can open the pkcs12 with openssl.
Check also if you can expoert after decoding.
openssl based64 -in EXPORTED.p12 -d -out DECODED.p12
M.
Related Content
