Warning message
changed question
Answered Question
Apr 19th, 2012
updated question
Correct Answer by Andy Dabell about 5 years 4 months ago
Just access the first router in the normal way then use the telnet or ssh command to access the second router.
Correct Answer by ictunit12 about 5 years 4 months ago
You need to configure the vty lines on one of the routers, so that you can either telnet or ssh to it.
On one of the routers, enter the following from global configuration mode, (router would be your router hostname):-
router#(config) line vty 0 15
router#(config-line) password cisco
router#(config-line) login
Save this and it should allow you telnet from one router to another.
Cheers
Overall Rating: 5 (2 ratings)
Correct Answer
ictunit12 Thu, 04/19/2012 - 12:56
Cheers
Correct Answer
Andy Dabell Thu, 04/19/2012 - 14:16
