LAN Traffic Not Getting Out on ASA 5505
Answered Question
Apr 19th, 2012
For some reason my ASA is preventing my traffic from going out. I've added some crumby access-list and applied it to NAT for it to work. I don't like this. I know it is not right, but I am not sure what part is wrong. I will highlight the stuff I have added to make it work. I don't see what I am missing. If I were to remove these lines my ASA could ping in both directions (in and out), but my LAN cannot do anything but ping the ASA. No other traffic is going out unless I have added these unsafe lines of code.
Please help!
interface Vlan1
nameif inside
security-level 100
ip address 10.0.0.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa822-k8.bin
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 75.75.75.75
name-server 75.75.76.76
access-list Split_Tunnel_ACL standard permit 10.0.1.0 255.255.255.0
access-list 1 extended permit ip any 10.0.0.0 255.255.255.0
access-list 1 extended permit icmp any any
access-list 1 extended permit tcp any 10.0.0.0 255.255.255.0
access-list 1 extended permit ip 10.0.0.0 255.255.255.0 any
access-list 1 extended permit icmp 10.0.0.0 255.255.255.0 any
access-list 1 extended permit tcp 10.0.0.0 255.255.255.0 any
access-list 1 extended permit udp 10.0.0.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool vpnpool_fixed 10.0.1.2-10.0.1.11 mask 255.255.255.0
ip local pool vpnssl_fixed 10.0.1.12-10.0.1.14 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 access-list 1
nat (inside) 1 0.0.0.0 0.0.0.0 outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 10.0.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set strong-des esp-3des esp-md5-hmac
crypto ipsec transform-set Mike_SET esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dynmap 30 set transform-set strong-des
crypto dynamic-map Mike 65535 set pfs group1
crypto dynamic-map Mike 65535 set transform-set Mike_SET
crypto map Mike 65535 ipsec-isakmp dynamic dynmap
crypto map OUTSIDE_MAP 10 ipsec-isakmp dynamic Mike
crypto map OUTSIDE_MAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 50
encryption 3des
hash sha
group 2
lifetime 86400
vpn-addr-assign local reuse-delay 1
vpn-sessiondb max-webvpn-session-limit 1
telnet 10.0.1.0 255.255.255.0 inside
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 30
ssh 10.0.1.0 255.255.255.0 inside
ssh 10.0.0.0 255.255.255.0 inside
ssh timeout 30
console timeout 0
management-access inside
dhcpd dns 10.0.0.1
dhcpd auto_config outside
dhcpd address 10.0.0.2-10.0.0.33 inside
dhcpd enable inside
Correct Answer by John Blakley about 5 years 3 months ago
Michael,
Take this off:
Add this:
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect http
  inspect icmp
service-policy global_policy global
Also, make sure that you are getting a default route from the provider. You can do a "show route" to see this.
HTH,
John
Overall Rating: 5 (1 ratings)
Correct Answer
John Blakley Fri, 04/20/2012 - 04:23
  • Purple, 4500 points or more
Michael,
Take this off:
Add this:
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect http
  inspect icmp
HTH,
John
Inmike0985 Mon, 04/23/2012 - 21:12
Thanks John!!
This is exactly what I needed to do. I was so tired of reading over and over my config that I completely didn't notice that I had tacked on the word "outside" on my nat (inside) 1 0 0 statement.
Thanks!
