MX200, MX300 calls across the WAN
Answered Question
Apr 20th, 2012
Hello
I have a sitation where we have telepresence units deployed accross 7 sites. when calls are made between sites, if my region setting is set to g729 between regions, calls will connect Audio Only. when i change my region settings to g711 between regions and try to call again Audio and Video works
is there a setting that i need to turn on in order to successfully make and receive calls between sites on G729 ?
thanks
I have my telepresence units registered to UCM 8.6 and the units are running the latest code
Correct Answer by Alok Jaiswal about 4 years 10 months ago
Hi Cristobal,
Curently the G.729 is not a supported codec for Mx200 and 300.
Audio standards
• G.711
• G.722
• G.722.1
• 64/128 kbps MPEG4 AAC-LD
check the link for more information.
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11302/ps11776/data_sheet_c78-669335.html
So in my view its not liking this.
Alok
Overall Rating: 5 (1 ratings)
