SSL VPN Session has not disconnected
Apr 20th, 2012
Good Day,
My SSL VPN users are loggin out after using it, but closing the browser.
But the session is still available in the browser and the next user when using the shared PC can have access.
How can I prevent this. Kindly advice.
Irfan
Overall Rating: 5 (1 ratings)
a.matahen Fri, 04/20/2012 - 11:52
This is indeed weird, I don't know a solution to what you are facing but using Cisco Secure Desktop [CSD] would be a workaround, try it out and check if it solves your problem.
Ahmad
