Warning message
ACS 5.3 - TACACS+ command authorization
Apr 20th, 2012
I'm doing an eval of ACS 5.3 for a client and i'm trying to integrate one of the routers into it using TACACS+.  I had the authentication working with an internal user.  when i went back in and added the authorization parts though, now i'm locked down to the enable prompt and can't do anything...trying to make sense of the documentation on how to assign the command sets, etc. to my test user, but it doesn't make any sense (this is some of the lousier documentation i've seen for a while...).
Does anyone have any thoughts on what to do to get the command sets to work?
SJ
Eduardo Aliaga Mon, 04/23/2012 - 19:21
  • Silver, 250 points or more
could you please post your acs config and your router config ?
Scott Jones Tue, 04/24/2012 - 06:21
Don’t mean to be ignorant about this, but is there a way to export the config from ACS? Router config section is below…I’ve used this successfully with 4.2 several times…
ip tacacs source-interface gi 0/0
tacacs-server directed-request
tacacs-server key
tacacs-server host x.x.x.x
aaa new-model
aaa authentic login default group tacacs+ local
aaa authentic login no-tacacs none
aaa authentic enable default group tacacs+ enable
aaa author config-commands
aaa author exec default if-authenticated
aaa author commands 1 default if-authenticated
aaa author commands 15 default group tacacs+ local
aaa author console
aaa account exec default start-stop group tacacs+
aaa account commands 0 default start-stop group tacacs+
aaa account commands 1 default start-stop group tacacs+
aaa account commands 15 default start-stop group tacacs+
aaa account connection default start-stop group tacacs+
aaa account system default start-stop group tacacs+
aaa session-id common
Scott Jones Thu, 04/26/2012 - 07:08
as a follow up...i'm looking at ACS now.  The way i have it setup is using the default 'permit all' for the device authorizations, shell profile, command  sets, etc.  It should let whatever commands i run through.  But, all i see on the router is 'command authorization failed'.  I can't even reload the thing now...
Is there a document somewhere that goes through step-by-step?
Tarik Admani Thu, 04/26/2012 - 14:35
  • Green, 3000 points or more
To get in you can change the shared secret in ACS so that the router will go into local mode, or you can just change the ip address of the router so ACS doesnt respond. That will let you in the router using your local credentials.
The shell profile that you are using, did you configure any other attributes like RBAC for other devices like nexus or WLC, if so you may want to switch the operand of mandatory to optional and then try you test again.
If you want to export your configuration you can go from the cli and issue the "acs backup...." to get the backup of your config, you will need to setup a repository to export this to.
tarik admani
Related Content
