Warning message
Cisco VPN Client issue while changing the vpn pool
We have already implemented Cisco client VPN service on Cisco ASA. My Cisco VPN ip pool is configured 174.26.4.0/22 & My corporate network pool is 172.26.4.0/22. which is working perfectly.
My concern is VPN pool 174.26.4.0/22 is comes under public range so i want to change this pool into private range (172.30.100.0/24)
so i changed below configuration.
no access-list nonat extended permit ip 172.26.4.0 255.255.252.0 174.26.4.0 255.255.252.0
no ip local pool testpool 174.26.4.0-174.26.4.253
access-list nonat extended permit ip 172.26.4.0 255.255.252.0 172.30.100.0 255.255.255.0
ip local pool testpool 172.30.100.1-172.30.100.254
After changing, i am able to connect vpn & vpn machine got ip address 172.30.100.1.
during VPN connection, vpn machine (172.30.100.1) is pinging from corporate network & even take the remote also but from VPN machine (172.30.100.1) I am not able to ping corporate network.
i am not able to understand where is my mistake?
Please help us
vinod Gupta
9810966625
mvsheik123 Sun, 04/22/2012 - 14:43
  • Gold, 750 points or more
Config will definitely help but did you check if the VPN client getting corp network routes? Check the splittunnel settings.
thx
MS
