04-21-2012 12:27 PM
Hallo to all,
I have Cisco router RV082 and I need to set up in this way. Ther should be two sunbnets.. each should have it´s own DHCP and each subnet should work in different external IP.. (one Internet port a and second DMZ/internet port)
Is it possible to set up? Can you help me?
Thank you very much...
04-21-2012 01:36 PM
The build-in DHCP Server of RV0xx supports only one IP subnet.
04-22-2012 02:01 AM
thank you .. that is what I din´t want to read..... :-(
04-23-2012 11:00 AM
It is possible for you to you use the VLAN functionality to seperate the subnets. Just have a DHCP server on both ends and disable the built-in one. Use traffic routing ot relocate the traffic from VLAN to WAN (by IP ranges).
