VCS Protocol Signalling to remote endpoint
Apr 22nd, 2012
HI,
   I would like to ask why my default protocol (H.323) on both site are being converted to SIP when calling to another VCS end-point via a H.323 call number format ?
Note : I configured both protocol (H.323 and SIP profile).
         Transmit                               Recieve
Singapore    Protocol      to      Hong Kong   Protocol
EX90           H.323                    EX90           SIP
Any idea how to fix this ?
Cheers,
ERik
Alok Jaiswal Sun, 04/22/2012 - 20:56
  • Silver, 250 points or more
Hi Erik,
Can you provide us more details. How the endpoint are registered to. Does both the endpoint registered to VCS control ??
Can you provide more details for your deployment?
Alok
Erik Estrada Sun, 04/22/2012 - 22:06
HI,
  I used single VCS Control Deployment
1. Singapore is my HQ site for my Tandberg Ex90 and C40
2. Hong Kong is my Branch site with EX90 and C40
All end-points are registered in VCS control
All used a Dual protocol registration (H.323 and SIP)
My understanding is that when you call from Singapore EX90 using the H.323 call format E.164 number in Hong Kong EX90 I should receive a signalling protocol of H.323 too, correct? but in this case my Hong Kong endpoint is converting the H.232 to SIP.
Erik
Dharmesh Nandoria Sun, 04/22/2012 - 23:48
  • Cisco Employee,
Hi Erik,
Please check following configuraion in end point ,
xConfiguration Conference 1 DefaultCall Protocol: H323
This shold be H323 in Ep from which you initiate call,
Can you please provide detail of  H323 id ,  e164 and sip uri configured on both units .Also have you configured any transform or search rule to add domin name which used for SIP dialing , Please deactivate it and try to make call.
Kind regards,
Dharmmesh
Erik Estrada Mon, 04/23/2012 - 00:01
Hi Dharmesh,
    I configured a default call protocol to H.323 on my end-points. I got a transform and search rule to add domain for SIP dialing.
   So I need to deactivate these policies ? But what if I call from my EX90 to SIP endpoint only like a E20 or CIUS, it may affect my call right ?
Cheers,
Erik
Alok Jaiswal Mon, 04/23/2012 - 00:30
Hi Erik,
One thing we need to know is how the endpoint registered to? What is the H.323 ID you configured on the remote endpoint?
if you are adding a sip domain to a E.164 number using a transform then you should have a h.323 id in that format.
VCS will try LRQ for h.323 using H.323 id and if it is not able to find one then initiate a SIP call and i guess you have registered the endpoint with E.164@ for SIP URI??.
So try to register the remote endpoint with h.323 id same as your SIP URI and then try the call again.
Also can you paste the search for the call by going into call history to know better what is happening actually
Alok
Erik Estrada Sun, 04/29/2012 - 21:50
  I'm sorry but I just tried your suggestion aS BELOW :
Singapore
closed H323
SIP
In Sydney office, have the same format
VCS control Call history is :
2012-04-30 12:23:58SG.EX90 H323 (XXXX)
XXXX H323 <-> SIP2 minutes 2 secondsNormal, unspecifiedLocalView
It still converting H.323 to SIP in my destination
any more idea?
thanks
Erik
Martin Koch Mon, 04/30/2012 - 02:37
  • Red, 2250 points or more
This looks wrong:
E164 :
[email protected]@domain.com
An e164 number shall only be a number. Besides that two at are not possible in an URI neither.
Most likely you have wrong search / transform / policy rules.
You did not give a feedback to Alok. The VCS can only find what you configure. For that its important
to check which aliases you have set up on the endpoint, that his shows up proper in the VCS registration
and that what you dial and the search rules fit to that. If its done right it will work great.
Alok Jaiswal Mon, 04/30/2012 - 03:48
Hi Erik,
Yes, this seems wrong. why you have a e.164 number as "[email protected]@domain.com". it has to be a number.
Currently looking the configuration you have the h.323 id is SG.EX90 H323 (XXXX) (don't know what xxx is). So you should dial this alias and then you have necessary search rules to route the calls.
however i would like you to change the configuration of endpoint and test again. Under H.323 ID on the endpoint you should configure the ID as [email protected]  if you are using the aliases to dial. This way the call setup would be thorugh H.323 to the alias [email protected]. Also put some number under the E.164 field of the endpoint.
After this, check whether the call connects and what is the protocol it use.
if it fails or still do an interwork (which it shouldn't be) then post the search details for the call from VCS.
Alok
Related Content
