OTV with Overlapping VLANs
Apr 22nd, 2012
How do you handle overlapping vlans when using OTV between Data Centers.  i.e. in Data Center 1 i have vlan 100 with ip address 10.10.100.0/24 and in Data Center 2 I have vlan 100 with ip address 10.20.100.0/24.  I don't want to combine these into one network but keep them seperate when extending them between Data Centers..  Can OTV re-assign the vlans?  or do i have to ensure the vlan tags are unique between the data centers?
Thanks.
Bill
bicakhanb Sun, 04/29/2012 - 02:12
Then you need seperated OTV edge devices for each DC which has overlapped vlans. You can increase the number up to three at this moment by using VDC feature. OTV doesn't support qinq or similar mechanisms yet.
bill.greenwood Sun, 04/29/2012 - 05:00
Evan with a separate VDC the only way I can think of to translate the vlans is too connect access ports for each vlan that needs to be translated. This is not a practical solution for a large number of vlans as it would use a large number of ports on the Nexus 7K. If a trunk is used the vlan tags are passed through. Is there another way?
Bill
Related Content
