UC500 - Silent Ring
Answered Question
Apr 22nd, 2012
A customer today asked for the technical support blast group, if they could add another extension to ring silently giving them the opportunity to answer the call. They refered to it as a silent ring. Does anyone have an idea what they are reffering too.
Correct Answer by mdobiac about 4 years 11 months ago
Mr. Culp,
Good morning, as it sounds it looks like you have a user on the network that wants the option to answer for the blast group but does not want to hear his phone ring.  Depending if you buttons available and using CCA 3.2 I would create a button to be an additional extension and associate that extension to the Blast group, and under ring parameters select silent ring.  This will allow the user to be a part of the Blast group and it will not cause his phone to ring and just see that button associated to the Blast group flash Amber when a call is coming in across the Blast group.
Hope this helps,
Mike D.
Overall Rating: 5 (1 ratings)
Alexander Maroukian Sun, 04/22/2012 - 22:59
  • Cisco Employee,
Maybe group pickup (Gpickup). Or group pickup with monitor on one extention. Or just share one of the blast group members number with another extension. There is also for non-business hours night service bell which do this.
HTH,
Alex
*Please rate helpful answers
Paolo Bevilacqua Mon, 04/23/2012 - 04:26
  • Hall of Fame,
    Founding Member
Silent ring is done using 's' in button command. This is CLI command. I don't know and don't discuss GUI or CCA.
Correct Answer
mdobiac Mon, 04/23/2012 - 06:31
  • Bronze, 100 points or more
Mr. Culp,
Hope this helps,
Mike D.
