Regarding Quick set C20
Apr 23rd, 2012
Dear Experts!!!!
I need a solution for video conference for connecting 20 locations with Quick set C20
At a time, i want two parties only can talk????
Will you suggest me what are all the technical part codes required for this solution and what is the bandwidth required for each location??
Is we need to have CUCM for this solution or standalone will work????
Janardhan
Oleksandr Yurchenko Mon, 04/23/2012 - 03:30
  • Silver, 250 points or more
Hi Janardhan
You dont need to have CUCM for your scheme.
You need  select required  MCU with necessary number of ports.
For 20 endpoins may be MCU4510.
Br. Oleksandr
Haydn von Imhof Mon, 04/23/2012 - 03:47
Purchasing a MCUwould be the best for your requirements.
An MCU would also give extra functionally such as a basic Gatekeeper.
Also the bandwidth you would need for each site would depend on the call speed you select.
When using a MCU you have the ability to call different site at different bandwidths (64kbps to 4Mbps) all from the same conference, which means you can match the call speeds to your individual sites capabilities.
MCU Data Sheet
http://www.cisco.com/en/US/prod/collateral/ps7060/ps11305/ps11317/ps11341/data_sheet_c78-627482.html
