%IVR-3-LOW_CPU RESOURCE: on VG 2821
Apr 23rd, 2012
Hi all,
i´ve a got a problem with a 2821 voice gateway and i see the following message in log file
Apr 23 16:04:37.338: %IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu
utilization (96/100).
     Call (callID=382702) is rejected.
sh version
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-ipvoicek9-mz.124-24.T1.bin"
sh processes cpu history
1 1 21 11 1 31 999999999999999
455526444515430465555168455637615765556777877677666606666566
100 *#***** *******
90 *####*****##*#
80 *####****#####
70 *######*######
60 *#############
50 *#############
40 ##############
30 * ##############
20 * * ** ##############
10 ***** *** #* ******** ***#**#************###############*
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
99998962 9 9 98 9 99 1 49 1 4199
777737636555555555555565556575555555555555557668778392786855555515588177
100 **** * * * * * ** * **
90 **** * * * ** * ** * **
80 ****** * * ** * ** * **
70 ******* * * ** * ** * **
60 ******* * * ** * ** * **
50 ******* * * ** * ** * * **
40 ******* * * ** * ** ** * **
30 #*##*** * * ** * ** ** * **
20 #*##*#** * * ** * #* *# * **
10 ####*#********************#*#*******************##****#***************##
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
sh processes cpu sorted 1min
CPU utilization for five seconds: 4%/0%; one minute: 3%; five minutes: 3%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
68 8663700 112909121 76 1.03% 1.01% 0.98% 0 Skinny MOH Serv
e
156 150020 563217513 0 0.47% 0.42% 0.40% 0 HQF Shaper Back
g
5 4823316 341002 14144 0.95% 0.30% 0.25% 0 Check heaps
9 79184 7652091 10 0.31% 0.25% 0.24% 0 Skinny Msg Serv
e
272 22188 141573071 0 0.15% 0.13% 0.13% 0 HSRP Common
255 305324 639087 477 0.23% 0.12% 0.04% 0 VOIP_RTCP
265 604720 274136 2205 0.00% 0.07% 0.02% 0 CCSIP_SPI_CONTR
O
128 18004 3517829 5 0.07% 0.04% 0.05% 0 CEF: IPv4 proce
I cannot find anything on cisco web page for this issue and this firmware. Anybody an idea what can i do?!
Many thanks,
cristina
Paolo Bevilacqua Mon, 04/23/2012 - 08:07
  • Hall of Fame,
    Founding Member
Seem there is nothign to worry about.
I'd recommend you update IOS anyway...
acampbell Mon, 04/23/2012 - 08:56
  • Green, 3000 points or more
Cristina,
This what the error decoder thinks of your alarm
1.
%IVR-3-LOW_CPU_RESOURCE:IVR: System experiencing high cpu utilization ([dec]/100). Call (callID=[dec]) is rejected.\n
The system does not have enough CPU resources available to accept a new call.
Recommended Action: Ensure that the call setup rate is within the supported capacity of this gateway.
Related documents- No specific documents apply to this error message.
I am with Paolo, I would upgrade the IOS first of all
If you have at least 256M DRAM & 64M Flash
Use c2800nm-ipvoicek9-mz.124-24.T7.bin
Alex
