Warning message
IP on VLAN or IP on Loopback in VLAN
Answered Question
Apr 23rd, 2012
On a current Catalyst product Is it better to assign an IP address directly to a VLAN interface or to assign an IP address to a Loopback interface that is in a particular VLAN?  What are the benefits or pitfalls of either method?
Correct Answer by Dan-Ciprian Cicioiu about 5 years 3 months ago
Hi ,
You cannot configure the loopback interface as switchport. Also you cannot configure a SVI ( interface vlan ) as a switchport. So the solution is to configure the IPs on the interface vlan.
Dan
Overall Rating: 5 (1 ratings)
glen.grant Mon, 04/23/2012 - 09:42
  • Purple, 4500 points or more
  Not sure what you mean by a loopback address in a given vlan.  Generally you would have a single loopback for a given L3 device and this is used by any dynamic routing protocols like ospf or eigrp as this interface is always in a up/up state .
kpieckiel Mon, 04/23/2012 - 09:56
What I mean by that is creating a loopback interface and placing it in the particular VLAN as opposed to assigning the VLAN interface an IP address directly.  So, for example, let's take a Catalyst 6506.  If I'm hosting three VLANs 10-12 that need IP addresses (default routes for three different networks) I would potentially have three loopback interfaces with an IP address (one in each subnet consumed by those VLANs).  The alternative is to instead assign the VLAN interfaces the IP addresses and not mess with loopback interfaces.
So lets give an example.  Normally I just assign addresses to the VLANs thusly:
int vlan10
description Fiscal
ip address 10.10.10.1
int vlan11
description IT
ip address 10.10.11.1
int vlan12
description Maintenance
ip address 10.10.12.1
I'm asking if it's good, bad, or indifferent to use loopback interfaces instead:
int vlan10
description Fiscal
no ip address
int vlan11
description IT
no ip address
int vlan12
no ip address
int lo10
switchport
switchport access vlan 10
switchport mode access
int lo11
switchport
switchport access vlan 11
int lo12
switchport
switchport access vlan 12
Correct Answer
Dan-Ciprian Cicioiu Mon, 04/23/2012 - 10:03
  • Gold, 750 points or more
Hi ,
Dan
Related Content
