ccx 7.x and Unified Presence
Answered Question
Apr 23rd, 2012
When these two applications exist within the enterprise telephony environment are they distinctly seperate or are they integrated womewhat?
Just want to understand if there is integration betweeen the applications or do they stand alone.
Paul.
Correct Answer by anchoudh about 5 years 3 months ago
Hi Paul,
UCCX CAD client is the software used by the Contact Center Agents.
CUPC is the client used with CUPS server.
These two client applications are different from one another.
You can integrate UCCX with CUPS server, for Agents (CAD) and Supervisors (CSD) for contacting the SME (Subject matter Experts) who will be using the CUPC clients.
Please refer the section "Configuring the Cisco Unified Presence Cluster" from page 169 onwards in the below link,
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/user/guide/cda66ug-cm.pdf
Also refer the below UCCX comp matrix for the UCCX and CUPS compatiability,
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Hope it helps.
Anand
Please rate helpful posts !!
Overall Rating: 5 (1 ratings)
pvarenholt Mon, 04/23/2012 - 09:05
sorry about the typos in there....
running ccx CAD and CUPC on the desktop and currently don't yet have the CUPC rolled out yet.
Just want to know what to expect.
Paul.
Correct Answer
anchoudh Mon, 04/23/2012 - 09:08
  • Red, 2250 points or more
Hi Paul,
Hope it helps.
Anand
pvarenholt Wed, 05/02/2012 - 04:59
Great doc however, not seeing where the menus are located.
I'm running presence ver 8.5.
There is no menu labled "Cisco Unified Presence Settings" as shown in
Figure 81. Cisco Unified Presence Cluster Settings page
Also, configuring contact lists - can't find that either....
Cisco Desktop Presence Administration - no idea where to find this tool / utility.
Don't see where this is;
To create a contact list:
1.Choose Cisco Unified Presence Settings > Contact Lists. The Contact Lists page appears (Figure 82).
Figure 82. Contacts Lists page
Paul.
anchoudh Wed, 05/02/2012 - 05:27
Hi Paul,
UCCX 7.x version is compatible only with CUPS version 6.0.1, 7.0.1 and 7.0.5, please refer the below comp matrix.
So have the correct versions of CUPS and UCCX for integration.
On your UCCX box, navigate to Start->Programs->Cisco->Desktop->Admin
Desktop Administrator Side A, it will open your WEB CDA.
http://xx.xx.xx.xx:6293/teamadmin/login.cda  (where xx.xx.xx.xx is your UCCX ip address).
Click on login and select the Cisco Unified Presence Settings tab on your left side.
It has your presence settings \ contact list...etc.
Hope it helps, please rate the helpful posts by clicking on the stars below the right answers.
Anand
anchoudh Tue, 04/24/2012 - 05:13
Hi Paul,
Is this info enough or you wanted some other information? Please do let us know. Incase if it has answered your query mark it as answered and rete the post accordingly.
Anand
pvarenholt Tue, 04/24/2012 - 07:07
This is exactly what i was looking for - thanks very much.
