1941W Wireless config
Apr 23rd, 2012
I just purchased a 1941w router to see if we want to use this to replace our existing routers and external access points. At each of our locations we have 1  subnet that has a server, AP, router, switch, etc.
I would like to configure the AP and the router in the 1941w in the same subnet but cannot figure out how to do this. If I setup the wlan-ap0 interface with an IP in the subnet I am using it will not let me assign an IP from that same subnet to any of the ethernet interfaces. It says they overlap.
No matter what I do I cant seem to use the same IP on both. I could if I purchased a 1941 without wireless and then purchased an aironet so why cant I do it when they are in the same box?
I'm not a cisco expert so I assume I'm just not doing something right. Any help appreciated.
Henrik Grankvist Mon, 04/23/2012 - 14:39
  • Silver, 250 points or more
You need to configure a bridged interface that is linked to your ethernet-interface and your wlan-ap0-interface. On the bridged-interface you set the IP-address. Search on cisco's website to set it up.
denstjames Tue, 04/24/2012 - 05:35
Thank you for the reply but when I try to bridge the wlan-ap0 interfae it says it does not support bridging. This is the command I used:
bridge-group 1
This isthe output I get
wlan-ap0 does not support bridging
Any other ideas?
jos.moonen Sat, 06/02/2012 - 01:29
You need to create a vlan en BVI interface in you're config
ip dhcp pool LAN-WiFi
import all
network 192.168.0.0 255.255.255.0
dns-server 194.109.6.66 194.109.9.99
default-router 192.168.0.1
domain-name WORKGROUP
lease 7
interface wlan-ap0
ip unnumbered BVI1
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
no cdp enable
bridge-group 1
hold-queue 100 out
interface Vlan1
no ip address
bridge-group 1
interface BVI1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip route-cache
and do not forget
bridge 1 protocol ieee
bridge 1 route ip
in you're AP config you can set both ( 2.4 and 5Ghz ) to the vlan1
now the LAN and WLAN have the same IP range.
Related Content
