Warning message
6500 Supervisor Modules CATOS
Answered Question
Apr 23rd, 2012
Hello All,
I have a question. I have a 6500 with two supervosrs and they both have CATOS. One of them failed and I need to replace. As long as the hardware is the same does the CATOS have to be indentical or can this be different.
Correct Answer by krahmani323 about 5 years 3 months ago
Hello John, Leo,
Within a 6500 system with redundant 6500 CatOS the images need to be the same. But this is not required when inserting a new module with different CatOS because at bootup the new backup supervisor image will be synchronized to the active.
On the standby the new image like "BTSYNC_cat6000…" should be automatically downloaded.
Pay also attention to the RAM/FLASH memory requirments of the image in the new card. If there is no free space a question may be asked to erase the old image.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_example09186a0080a98f3c.shtml#hm
By default on the Cisco Catalyst 6500 Series  Switch, the Catalyst OS software images on the active and the standby  Supervisor Engines must be the same. If the two supervisor images are  not the same version during system bootup, the active Supervisor Engine  downloads its current boot image to the standby Supervisor Engine. The  NVRAM configuration of the active Supervisor Engine is also synchronized  between the Supervisor Engines.
Of course the goal is to reach the high availailability operational mode between the two cards => show system highavailabilty need to be enabled and operational.
There is some specificities regarding versioning feature which allows to run different images with still highavailability but I would not pay attention to this feature :
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/redund.html#wp1046825
Check also for this complete document => http://www.cisco.com/warp/public/cc/pd/si/casi/ca6000/tech/hafc6_wp.pdf
discussing on the global redundancy on the SUP, but also on the MSFC !
Regards.
Karim
Overall Rating: 5 (1 ratings)
Leo Laohoo Mon, 04/23/2012 - 15:09
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
The replacement supervisor has to be the same model and with the same DFC/PFC card.  The replacement supervisor should also have the same version of CatOS and must NOT contain any configuration and/or VLAN database file.
Correct Answer
krahmani323 Mon, 04/23/2012 - 15:49
  • Silver, 250 points or more
Hello John, Leo,
Regards.
Karim
Leo Laohoo Tue, 04/24/2012 - 17:02
  • Hall of Fame,
    2017 LAN, Wireless
Thanks Karim.
