Warning message
Cisco 1941W really basic configuration
Apr 23rd, 2012
Ok, I am replacing a cisco linksys router with a 1941w.
I have the 0/0 accepting a DHCP from the ISP then I have 0/1 going to a switch and hosting a dhcp server.
Where I have an issue is:
A) Finding a way to turn on the wireless and make it use the same DHCP as wired and setting up a user name/wep password
B) Turning on the GUI that is supposed to be embedded on this.
C) Finding a way to make the DNS point to the default gateway so that I don't have to set the address everytime we move the box.
Here is my current configuration, and with it I can get onto the wired network and get to the internet.
Current configuration : 4712 bytes
! No configuration change since last restart
version 15.1
hostname GWwireless
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$rM0I$vA2.k0k2KgEXgCsfwTPnA/
no aaa new-model
memory-size iomem 10
clock timezone CST -5 0
service-module wlan-ap 0 bootimage autonomous
no ipv6 cef
ipv6 spd queue min-threshold 30
ipv6 spd queue max-threshold 31
ip source-route
no ip icmp rate-limit unreachable
no ip icmp rate-limit unreachable DF
ip cef
ip dhcp excluded-address 192.168.0.1 192.168.0.21
ip dhcp pool DHCP_POOL
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 192.168.254.254
domain-name ciscolab.local
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-2933970575
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2933970575
revocation-check none
rsakeypair TP-self-signed-2933970575
crypto pki certificate chain TP-self-signed-2933970575
certificate self-signed 01
license udi pid CISCO1941W-A/K9 sn FTX161281R7
hw-module ism 0
username admin privilege 15 secret 5 $1$DGu6$CVE6S3f5GVoy6JED4kzAx/
username wind privilege 15 password 0 cisco
username goldwind privilege 15 secret 5 $1$aOqP$9oyOrr8ROP8pJ35tP0vAB1
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered GigabitEthernet0/0
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
ip address 192.168.0.1 255.255.255.0
ip nat inside
duplex auto
speed auto
hold-queue 32 in
interface Wlan-GigabitEthernet0/0
description Internal switch
no ip address
interface Vlan1
ip address 10.1.1.1 255.240.0.0
interface Vlan20
ip address 172.16.20.1 255.240.0.0
interface Vlan21
no ip address
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0/1 overload
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 0.0.0.0 0.0.0.0 192.168.254.254 254
access-list 1 permit 10.0.0.0 0.15.255.255
access-list 10 permit 192.168.0.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
banner exec ^CC
% Password expiration warning.
-------e username and password you want to
use.
--------------------------------OWN
CREDENTIALS
Here are the Cisco IOS commands.
username <myuser>  priv
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE  PUBLICLY-KNOWN
CREDENTIALS
username <myuser>  privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL NOT BE ABLE
TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
exec-timeout 30 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
access-class 23 in
exec-timeout 30 0
privilege level 15
password test3
login
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Stephen Rodriguez Tue, 04/24/2012 - 14:36
  • Purple, 4500 points or more
In order to configure the AP module you need to first do a session into the WLAN-AP0 service module.
Once you get into that the Ap should pull an address in VLAN 1, which the gig interface belong to by default.
From then, you should be able to hit the web page using the address the module pulls.
Steve
tigers692 Wed, 04/25/2012 - 20:54
I am not too sure how to do that, I've never configured a wireless cisco router. what do I enter on my terminal service?
Stephen Rodriguez Thu, 04/26/2012 - 08:36
from the router it should be service-module wlan-ap0 session.
Steve
andrewokri Thu, 05/31/2012 - 04:18
I have just cracked open a brand new 1941 box. For reason unknown to me, it has arrived without any manuals or CD or instruction on how to configure this device. This is the 1st time to use this device or any device from Cisco. I find myself in exactly the same position as the author of this thread. I have also found the answers given to his question to be unclear and has not helped me undersatnd how to get started. Please would anyone be willing to give us a dummy's guide to getting started with the 1941. What are the ways to interface with this device to configure it from a laptop? Or any other way for that matter? Thank you in advance.
tigers692 Thu, 05/31/2012 - 07:47
I find it very odd that no seems to be able to help, if you purchase an inexpensive linksys router it has an easy to use embedded web interface. With this you have to use a cisco console cable that doesn't come with the unit and use hyperterminal. Seems overly complicated, but I am trying to do a very simple task and can't even get help.
andrewokri Thu, 05/31/2012 - 08:05
This is what l have discovered so far:-
1. Getting a connection to the Router see
http://www.cisco.com/en/US/docs/routers/access/1900/hardware/installation/guide/19cable.html#wp1057624
2. Configuring the router, check out this thread for tips:-
https://supportforums.cisco.com/thread/2028286?tstart=0#3123587
I shall update further as l get along.
Configuring Hostname and Password
http://www.cisco.com/en/US/docs/wireless/mwr_1941/software_configuration/current_scg/DCNcfg.html?referring_site=smartnavRD#wp1096124
This link contains info for configuring the ethernet port GE 0/0 and GE0/1 also.
3. Configuring Wireless LAN
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/wlan.html
Related Content
