04-23-2012 10:03 PM - edited 03-17-2019 11:05 PM
Hi All,
I was wondering, is it possible to synch the TMS (server) Phonebook to the Codec (C20,40,60) Local Phonebook?
I have checked on the admin guides and also on this forum but no success.
Thank you in advance
Cheers
Hugh
Solved! Go to Solution.
04-23-2012 10:22 PM
Hi unfortunately this is not possible with the c-series as it does not support downloaded phonebooks. The MXP in comparison does support this.
/Magnus
04-23-2012 10:22 PM
/Magnus
04-23-2012 10:47 PM
Thanks for the response appreciate it.
