Warning message
ASA 5510 Unable to get internal networks talking to each other
Answered Question
Apr 23rd, 2012
Hey,
In need of some help here. I am tasked with transfering all clients from one subnet to the other. I figure the nicest way to do this is to temporarily have the subnets talk to each other in an endeavour to avoid as much downtime as possible. The two internal subnets are:
192.168.0.0/24
192.168.43.0/24 (the intended migration network)
I am beating my head against the desk here as I dont seem to be getting anywhere after the changes I have made. The current configuration is as such:
ASA Version 8.2(5)
hostname ciscoasa
domain-name *****
enable password ***** encrypted
passwd ***** encrypted
names
interface Ethernet0/0
description Internode SOHO
nameif Outside
security-level 0
ip address dhcp setroute
interface Ethernet0/1
description *****
nameif Inside
security-level 100
ip address 192.168.43.1 255.255.255.0
interface Ethernet0/2
description *****
nameif Main_Network
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Ethernet0/3
description *****
nameif DMZ
security-level 100
ip address  *****
interface Management0/0
nameif management
security-level 100
ip address  *****
management-only
ftp mode passive
dns domain-lookup Outside
dns server-group DefaultDNS
name-server  *****
name-server  *****
domain-name  *****
same-security-traffic permit intra-interface
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object udp
protocol-object tcp
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object udp
protocol-object tcp
access-list Outside_1_cryptomap extended permit ip 192.168.43.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list Inside_nat0_outbound extended permit ip 192.168.43.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list Inside_access_in extended permit ip 10.0.0.0 255.0.0.0 192.168.43.0 255.255.255.0
access-list Inside_access_in extended permit ip 192.168.43.0 255.255.255.0 10.0.0.0 255.0.0.0
access-list outside extended permit ip any 192.168.0.0 255.255.255.0
access-list outside extended permit ip any any
access-list Main_Network_access_in extended permit ip 192.168.0.0 255.255.255.0 any
access-list Main_Network_access_in extended permit ip any 192.168.0.0 255.255.255.0
access-list Main_Network_access_in extended permit ip 192.168.0.0 255.255.255.0 192.168.43.0 255.255.255.0
access-list Main_Network_access_in extended permit ip 192.168.43.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list Main_Network_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 any
access-list FTPinDMZ extended permit ip 203.30.186.0 255.255.255.0 any
access-list FTPinDMZ extended permit ip any 203.30.186.0 255.255.255.0
access-list Internal_Traversal extended permit ip 192.168.0.0 255.255.255.0 192.168.43.0 255.255.255.0
access-list Internal_Traversal extended permit ip 192.168.43.0 255.255.255.0 192.168.0.0 255.255.255.0
pager lines 24
logging enable
logging buffered errors
logging asdm errors
logging flash-bufferwrap
mtu Outside 1492
mtu Inside 1500
mtu Main_Network 1500
mtu management 1500
mtu DMZ 1500
failover timeout -1
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (Outside) 1 interface
nat (Inside) 0 access-list Internal_Traversal
nat (Inside) 0 0.0.0.0 0.0.0.0
nat (Main_Network) 1 access-list Main_Network_nat0_outbound
nat (Main_Network) 1 192.168.0.0 255.255.255.0
nat (DMZ) 1 203.30.186.0 255.255.255.0
static (Main_Network,Outside) tcp interface www Mail02 www netmask 255.255.255.255
static (Main_Network,Outside) tcp interface smtp Mail02 smtp netmask 255.255.255.255
static (Main_Network,Outside) tcp interface ssh Mail02 ssh netmask 255.255.255.255
static (Main_Network,Outside) tcp interface 993 Mail02 993 netmask 255.255.255.255
static (Main_Network,Outside) tcp interface 995 Mail02 995 netmask 255.255.255.255
static (Main_Network,Outside) tcp interface https Mail02 https netmask 255.255.255.255
static (Main_Network,Outside) udp interface 60001 192.168.0.185 3389 netmask 255.255.255.255
static (Main_Network,Outside) tcp interface 60001 192.168.0.185 3389 netmask 255.255.255.255
static (Main_Network,Inside) 192.168.0.0 192.168.0.0 netmask 255.255.255.0 norandomseq nailed
access-group outside in interface Outside
access-group Main_Network_access_in in interface Main_Network
route Outside 10.0.3.0 255.255.255.0 SOHO_ADSL 1
route Outside 192.168.0.0 255.255.255.0 SOHO_ADSL 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 200.200.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp Inside
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map Outside_map 1 match address Outside_1_cryptomap
crypto map Outside_map 1 set pfs
crypto map Outside_map 1 set peer *****
crypto map Outside_map 1 set transform-set ESP-3DES-MD5
crypto map Outside_map interface Outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
hostname ciscoasa
domain-name *****
names
nameif Outside
security-level 0
description *****
nameif Inside
security-level 100
description *****
nameif Main_Network
security-level 100
description *****
nameif DMZ
security-level 100
ip address  *****
nameif management
security-level 100
ip address  *****
management-only
ftp mode passive
name-server  *****
name-server  *****
domain-name  *****
protocol-object udp
protocol-object tcp
protocol-object udp
protocol-object tcp
protocol-object udp
protocol-object tcp
access-list FTPinDMZ extended permit ip *****
access-list FTPinDMZ extended permit ip any *****
pager lines 24
logging enable
logging asdm errors
mtu Outside 1492
mtu Inside 1500
mtu management 1500
mtu DMZ 1500
failover timeout -1
arp timeout 14400
nat-control
nat (DMZ) 1 ****
http server enable
crypto map Outside_map 1 set peer 159.153.222.18
crl configure
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
crypto isakmp enable Outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 130
encryption 3des
hash md5
group 2
lifetime 10800
telnet timeout 5
ssh 192.168.43.0 255.255.255.0 Inside
ssh 192.168.0.0 255.255.255.0 Main_Network
ssh timeout 5
console timeout 0
management-access Main_Network
vpdn username  ***** password  ***** store-local
dhcp-client client-id interface Outside
dhcpd address 200.200.1.2-200.200.1.200 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
username  ***** password  ***** encrypted
tunnel-group  ***** type ipsec-l2l  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
tunnel-group  ***** ipsec-attributes
pre-shared-key *
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
encryption 3des
hash md5
group 2
lifetime 86400
encryption 3des
hash md5
group 2
lifetime 10800
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
Upgrading the firmware is not really an option
Hoping someone can help. Perhaps its just something right in front of me that Im missing.
Thanks in advance for any help
Correct Answer by Jouni Forss about 5 years 3 months ago
Try adding same-security permit inter-interface. (you have the other one configured that allows traffic to enter and leave on the same interface) This should permit traffic between 2 interfaces of equal security-level
Also you should configure an access-list for the inside interface.
Try the connections after that.
You also seem to lack basic PAT configuration for Inside interface for internet traffic. (As you only have ID 0 NAT statements configured)
For ICMP between the 2 networks please add
  inspect icmp
- Jouni
Overall Rating: 5 (1 ratings)
Correct Answer
Jouni Forss Tue, 04/24/2012 - 00:48
  inspect icmp
- Jouni
VampiressX Tue, 04/24/2012 - 02:56
OMG thankyou so much Jouni! Awesome. I just cant believe I missed that one. So you are actually required to have both statements... inter and intra.
I also noticed that ive double posted the config. God the things you do. Anywho, my very special thanks to you and you have saved me many days of heartache with that. Cheers m8!
Jouni Forss Tue, 04/24/2012 - 23:16
Glad that it works now
To my understanding the command with the "intra" parameter is for situations where the traffic is entering and leaving the same interface. One of the most common situations where I need this command is when a customer has a Client VPN configured and the VPN Client user needs to use Internet through the VPN Client (Outside to Outside interface traffic)
The "inter" parameter refers to situations where you need to pass traffic between 2 firewall interfaces which are configured with the same "security-level" value (As you did in this case).
- Jouni
Related Content
