Unable to apply Ip-Policy Route-map to Vlan 4 in C-3750
Answered Question
Apr 23rd, 2012
Hi all,
Here is my configuration below , i have upgraded my C-3750 switch IOS from IPbase to IPservices , after upgrading i have tried to apply PBR on my Vlan 4 and failed , when i am tying to apply route-map to Vlan4 the command was taking but i am unable to see the route-map when sh run , i am giving the command as "ip policy route-map TTSL" in my Vlan4 , please check the below configuration and help me on this.
In Vlan2 i have connected one ISP and Vlan4 I have connected one ISP , my local subnets are 192.168.1.x and 192.168.2.x , now i want to route the 192.168.1.x traffic from Vlan2 and 192.168.2.x Traffic from Vlan4 .
sh boot
coreswitch#sh boot
BOOT path-list      : flash:c3750-ipservices-mz.122-35.SE5/c3750-ipservices-mz.122-35.SE5.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
coreswitch#sh ver
coreswitch#sh version
Cisco IOS Software, C3750 Software (C3750-IPSERVICES-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01280000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
coreswitch uptime is 12 hours, 27 minutes
System image file is "flash:/c3750-ipservices-mz.122-35.SE5"
cisco WS-C3750G-24T (PowerPC405) processor (revision M0) with 118784K/12280K bytes of memory.
Processor board ID FDO1203Y78G
Last reset from power-on
3 Virtual Ethernet interfaces
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1F:6D:28:1F:80
Motherboard assembly number     : 73-9679-10
Power supply part number        : 341-0048-03
Motherboard serial number       : FDO12020PXJ
Power supply serial number      : LIT114602GH
Model revision number           : M0
Motherboard revision number     : C0
Model number                    : WS-C3750G-24T-S
System serial number            : FDO1203Y78G
Top Assembly Part Number        : 800-25855-01
Top Assembly Revision Number    : G0
Version ID                      : V05
CLEI Code Number                : COMR100BRA
Hardware Board Revision Number  : 0x02
Switch   Ports  Model              SW Version              SW Image
*    1   24     WS-C3750G-24T      12.2(35)SE5             C3750-IPSERVICES-M
Configuration register is 0xF
coreswitch#sh run
coreswitch#sh running-config
Building configuration...
Current configuration : 2599 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname coreswitch
enable password precicore
username admin password 0 admincore123
no aaa new-model
clock timezone UTC 5 30
switch 1 provision ws-c3750g-24t
system mtu routing 1500
ip subnet-zero
ip routing
ip name-server 125.62.193.121
ip name-server 123.108.200.163
ip name-server 121.242.190.210
ip name-server 121.242.190.181
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/1
switchport access vlan 2
interface GigabitEthernet1/0/2
switchport access vlan 4
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
switchport mode access
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface Vlan1
no ip address
shutdown
interface Vlan2
interface Vlan4
description TTSL
ip address 192.168.2.1 255.255.255.0
ip helper-address 192.168.1.5
ip classless
no ip route static inter-vrf
ip route 0.0.0.0 0.0.0.0 192.168.1.2
ip http server
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
route-map TTSL permit 20
match ip address 102
set ip default next-hop 192.168.2.3
control-plane
line con 0
line vty 0 4
password admin123
login
length 0
line vty 5 15
login
end
coreswitch#
Correct Answer by mukremin13 about 5 years 6 days ago
if 192.168.1.5 is dc. The packet which are starting from 192.168.2.x subnet never reach there.
Because of this acl "access-list 102 permit ip 192.168.2.0 0.0.0.255 any" whole packets forwarded to 192.168.2.3
You must define destination network instead of using "any".
i have similar problem with 3560. My problem is "set ip next-hop verify availability" is in the unsupported command list. So this happened. May be "set ip default next-hop" is in the unsupported list of 3750. Try to use set ip next-hop instead of this. and check 3750 configuration guide for unsupported command.
mukremin
Overall Rating: 5 (2 ratings)
Correct Answer
mukremin13 Mon, 04/23/2012 - 22:40
mukremin
Hari Kumar Raja Mon, 04/23/2012 - 22:49
Thanks Mukremin ,
I works for me , the PBR was succeed .
Appriciate your help
Hari
Hari Kumar Raja Mon, 04/23/2012 - 22:55
Hi Mukremin,
this works , but here we have one more issue , i am unable to ping the Switch Gateway from any 192.168.2.x subnet , it is directly redirecting to my 192.68.2.x firewall , in this case the dhcp will not assign to any 2.x pool.
please advise
Hari
mukremin13 Mon, 04/23/2012 - 23:03
who is 192.168.2.3 and 192.168.1.2 and 192.168.1.5
Hari Kumar Raja Mon, 04/23/2012 - 23:10
Hello ,
192.168.2.3 is my Firwall which has connected to Vlan 4 ( Gateway i am using for 2.x Subntes is Vlan4 - 192.168.2.1)
192.168.1.2 is my another Firewall which has connected to my Vlan 2 ( Gateway i am using for 1.x subnets Vlan2 - 192.168.1.1)
192.168.1.5 is my DHCP server which i want to use for both the subnets to serve the DHCP ips. 192.168.1.x and 2.x
Hari
Correct Answer
mukremin13 Mon, 04/23/2012 - 23:11
Hari Kumar Raja Mon, 04/23/2012 - 23:38
Here i am confusing , if i give the destination address 192.168.1.5 i am not able to ping the DC ,can you please send me the config how it looks like.
Hari
Hari Kumar Raja Tue, 04/24/2012 - 00:04
Thanks i have given the below access list and it works for me .
"access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.2.3 255.255.255.0"
Thanks a Ton for your help
Hari
