Switchport going to Error-disable frequently which is connected to Hub
Answered Question
Apr 24th, 2012
Hi Friends,
One of our swtich is frequently going to error-disable.
That switch port is connected to a hub and to that two PCs are connected.
Can you please suggest what is the problem and how to solve it.
Switch#sh interfaces gigabitEthernet 0/13
GigabitEthernet0/13 is down, line protocol is down (err-disabled)
  Hardware is Gigabit Ethernet, address is 503d.e508.4b0d (bia 503d.e508.4b0d)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 20:09:59, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1244435 packets input, 198757270 bytes, 0 no buffer
     Received 4177 broadcasts (252 multicasts)
     5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 252 multicast, 0 pause input
     2293998 packets output, 2192224484 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Configuration for that particular port
interface GigabitEthernet0/13
switchport access vlan 43
storm-control broadcast level 20.00
storm-control multicast level 20.00
please Help.
Correct Answer by Leo Laohoo about 4 years 11 months ago
Hmmm ... Do you see the result?
Shut/no shut the interface again and run the same commands. Make sure you wait for approximately 5 to 7 seconds.
If this is the same output then you MAY have a faulty cable.
Overall Rating: 5 (5 ratings)
sivaalthi85 Tue, 04/24/2012 - 05:30
I Have issued no shoutdown command and the port came up but afte sometime its again going to errordisable.
Please help.
Dan-Ciprian Cicioiu Tue, 04/24/2012 - 05:53
  • Gold, 750 points or more
Hi Siva,
You might have errdisable-recovery configured on the equipment, that's why the port got up without any manual action. Also you might have configure "storm-control action shutdown" which is one of the reasons that this is happening.
Dan
sivaalthi85 Tue, 04/24/2012 - 06:46
Hi Palani,
Below is the output of show logging on switch
pr 24 14:43:25.971:  DHCPD: address 10.127.43.104 mask 255.255.255.0
Apr 24 14:43:25.971:  DHCPD: reason flags: timeout 3.108
Apr 24 14:43:25.971:   DHCPD: htype 1 chaddr 000f.fe1c.bcc2
Apr 24 14:43:25.971:   DHCPD: out_vlan_id 0
Apr 24 14:43:25.971: DHCPD: returned 10.127.43.104 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:25.971: DHCPD: the lease for address 10.127.43.107 has expired.
Apr 24 14:43:25.971: DHCPD: Sending notification of TERMINATION:
Apr 24 14:43:25.971:  DHCPD: address 10.127.43.107 mask 255.255.255.0
Apr 24 14:43:25.979:  DHCPD: reason flags: timeout e.5906.79
Apr 24 14:43:25.979:   DHCPD: htype 1 chaddr 000f.fe1c.bd42
Apr 24 14:43:25.979:   DHCPD: out_vlan_id 0
Apr 24 14:43:25.979: DHCPD: returned 10.127.43.107 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:25.979: DHCPD: the lease for address 10.127.43.101 has expired.
Apr 24 14:43:25.979: DHCPD: Sending notification of TERMINATION:
Apr 24 14:43:25.979:  DHCPD: address 10.127.43.101 mask 255.255.255.0
Apr 24 14:43:25.979:  DHCPD: reason flags: timeout 3.110
Apr 24 14:43:25.979:   DHCPD: htype 1 chaddr 000f.fe1c.c10a
Apr 24 14:43:25.979: DHCPD: returned 10.127.43.101 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:25.979: DHCPD: the lease for address 10.127.43.109 has expired.
Apr 24 14:43:25.979:  DHCPD: address 10.127.43.109 mask 255.255.255.0
Apr 24 14:43:25.979:  DHCPD: reason flags: timeout 3.108
Apr 24 14:43:25.979:   DHCPD: htype 1 chaddr 000f.fe1c.c91e
Apr 24 14:43:25.979: DHCPD: returned 10.127.43.109 to address pool Teviot_Comm_Vlan.
Apr 24 14:43:26.390: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:29.410: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:31.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:32.967: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:33.973: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:38.411: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:40.676: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:46.296: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:48.402: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:43:50.709: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:50.709: DHCPD: interface GigabitEthernet0/13 coming up
Apr 24 14:43:51.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:43:55.515: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
sivaalthi85 Tue, 04/24/2012 - 06:34
Hi Dan,
No its not coming up automatically. All the time I'm logging into switch and issuing Shutdown and No shutdown command.
then  it coming up for sometime and again its going to error-disable.
There is no Strom control coomand given to the switch.
Before it was configured with portfast and BPDU gaurd but I have deleted it because
Spantree port fast start should only be enabled on ports connected
to a single host. Connecting hubs, concentrators, switches, bridges, etc. to
a fast start port can cause temporary spanning tree loops.
Regrads,
Siva
Ivan Krimmel Tue, 04/24/2012 - 06:38
Hey Siva,
it looks like time to time storm-control thresholds are being crossed over. Anyway, if you'd like the port to come up automatically, you can go for the global config command:
errdisable recovery cause
HTH,
Ivan.
sivaalthi85 Tue, 04/24/2012 - 06:49
Hi Ivan,
I have enable but still the port is flatuating.
24 14:46:03.643: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:08.097: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:10.874: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:12.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:19.682: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:21.695: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:23.490: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:28.465: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:35.763: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:43.480: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:50.787: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:55.736: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:46:57.045: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:46:59.058: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:02.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:04.192: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:06.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:08.453: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:11.557: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:13.570: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:17.144: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:23.343: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:24.929: %SYS-5-CONFIG_I: Configured from console by vty0 (192.168.18.27)
Apr 24 14:47:25.994: DHCPD: checking for expired leases.
Apr 24 14:47:26.992: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:26.992: DHCPD: interface GigabitEthernet0/13 coming up
Apr 24 14:47:27.999: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:33.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:37.268: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:46.328: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:48.333: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:50.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:51.260: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:53.265: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:53.265: DHCPD: interface GigabitEthernet0/13 coming up
Apr 24 14:47:54.280: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:47:56.134: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:47:59.884: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 24 14:48:06.570: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 24 14:48:06.570: DHCPD: interface GigabitEthernet0/13 coming up
Ivan Krimmel Tue, 04/24/2012 - 06:57
Thanks Siva,
it is good that we have logs now, it is clear that storm-control is not a culprit here, otherwise it would have shown that is has kicked in. It could be a hardware issue on that specific port, but let's check what is connected to this port on the other end and what do we have in the logs there. To avoid hardware issue you could use a spare port on this switch instead of port gige0/13.
Awaiting your update!
sivaalthi85 Tue, 04/24/2012 - 07:15
Hi Ivan,
An hub is connected to this port and to that Hub two Pcs corrected.
If I connect the cable to other port on the switch same thing is going on.
basically two pcs connected to hub and from hub their a cable connected to Switchport 13
Ivan Krimmel Tue, 04/24/2012 - 07:27
That's interesting Siva, thanks. I'd try these things(the order does not matter):
1) try to unplug one pc and see whether it will rectify the situation;
2) while the port is up, collect 'sh interface' output
3) run wireshark on one of the pc's - this will give you an idea what is going on in the wires;
4) try to play with duplex, for a hub it should be set to half;
5) remove storm-control knobs off the switch - I still suspect kind of storm due to a hub being connected;
Let me know how is it going.
sivaalthi85 Tue, 04/24/2012 - 07:40
HI Ivan,
Thank you so much for your time, I really appreciate.
I have couple of doubts on the steps you have suggested above. can you please breifly explain to me.
how to set half duplex on hub, its a 100mb hub and the port on switch is auto negogiate and the pcs connected to the hubs were auto nego but this morning i changed to full duplex but still problem is not solved.
I have no idea about the storm-control knobs . could you please explain. how to remove what is it actually used for
siva
Ivan Krimmel Tue, 04/24/2012 - 07:43
Siva,
my pleasure!
4) I meant to hardcode it on the switch. Though autoneg is a good thing, it maybe wise to manually code it, at least to try;
5) you have those in the config :
gotcha?
Ivan.
sivaalthi85 Tue, 04/24/2012 - 08:04
Hi Ivan,
I'm pasting configuration for couple of ports below.
interface GigabitEthernet0/12
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
sivaalthi85 Tue, 04/24/2012 - 07:17
Apr 24 14:50:39.234: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:50:42.531: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:50:51.490: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:50:53.000: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:50:55.013: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:50:57.362: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:01.682: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:06.220: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:08.233: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:11.178: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:20.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:23.626: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:25.640: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:26.009: DHCPD: checking for expired leases.
Apr 24 14:51:28.123: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:30.136: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:32.250: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:36.805: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:40.664: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:44.875: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:46.259: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:48.272: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:51:51.082: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 14:51:55.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 14:53:26.016: DHCPD: checking for expired leases.
Apr 24 14:55:26.024: DHCPD: checking for expired leases.
Apr 24 14:57:26.031: DHCPD: checking for expired leases.
Apr 24 14:59:26.038: DHCPD: checking for expired leases.
Apr 24 15:01:26.046: DHCPD: checking for expired leases.
Apr 24 15:01:33.252: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/8, changed state to down
Apr 24 15:01:34.250: %LINK-3-UPDOWN: Interface GigabitEthernet0/8, changed state to down
Apr 24 15:01:36.624: %LINK-3-UPDOWN: Interface GigabitEthernet0/8, changed state to up
Apr 24 15:01:36.624: DHCPD: interface GigabitEthernet0/8 coming up
Apr 24 15:01:37.630: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/8, changed state to up
Apr 24 15:03:26.053: DHCPD: checking for expired leases.
Apr 24 15:05:26.061: DHCPD: checking for expired leases.
Apr 24 15:07:21.882: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 24 15:07:23.895: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 24 15:07:26.068: DHCPD: checking for expired leases.
Apr 24 15:09:26.076: DHCPD: checking for expired leases.
Apr 24 15:11:26.083: DHCPD: checking for expired leases.
Apr 24 15:13:26.090: DHCPD: checking for expired leases.
Apr 24 15:15:26.098: DHCPD: checking for expired leases.
Switch# show clock
15:16:08.829 UTC Tue Apr 24 2012
fb_webuser Tue, 04/24/2012 - 08:09
  • Silver, 250 points or more
Check if err-disable for storm-control is enabled by doing the following:
NJ-SW#sh errdisable recovery | i storm-control
storm-control Enabled
If the output is ENABLED as shown above, please run the following command in config mode:
NJ-SW(config)#no errdisable recovery cause storm-control
and hit enter!!!!!!
Posted by WebUser Neeraj Jagga from Cisco Support Community App
sivaalthi85 Tue, 04/24/2012 - 08:22
Hi Web,
Switch#show errdisable recovery | i storm-control
Switch(config)#no errdisable recovery cause storm-control
Switch(config)#no errdisable detect cause all
Switch(config)#exit
Just given commands as you suggested
burleyman Tue, 04/24/2012 - 13:30
  • Blue, 1500 points or more
I see you said you set the PC's to full duplex, that is incorrect, they need to be hard set to half duplex, hubs only work in half duplex. Also on the port that the hub connects to on the switch you need to also hard code that to half duplex NOT auto. This causes duplex mismatching and will cause the port to erro-disable.
Mike
sivaalthi85 Wed, 04/25/2012 - 00:36
Hi Burleyman,
I will try what you have suggested and I ll reply soon.
Thank you so much for ur time..!!!!
sivaalthi85 Wed, 04/25/2012 - 00:33
Hi Web Still the problem is not solved.
Please help
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
no errdisable detect cause small-frame
no errdisable detect cause loopback
no errdisable detect cause gbic-invalid
no errdisable detect cause sfp-config-mismatch
no errdisable detect cause pagp-flap
no errdisable detect cause dtp-flap
no errdisable detect cause link-flap
no errdisable detect cause l2ptguard
no errdisable detect cause pppoe-ia-rate-limit
no errdisable detect cause dhcp-rate-limit
no errdisable detect cause arp-inspection
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause security-violation
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause l2ptguard
errdisable recovery cause psecure-violation
errdisable recovery cause port-mode-failure
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause pppoe-ia-rate-limit
errdisable recovery cause mac-limit
errdisable recovery cause vmps
errdisable recovery cause inline-power
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery cause small-frame
Leo Laohoo Tue, 04/24/2012 - 18:18
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Something is not right here.
If the interface goes into error-disable then the first question I'd be asking is WHY.  To know WHY the port(s) went into error-disable then use the command "sh interface status error".
Next, if the reason is "link flap" (or something in that vicinity) then I'd consider running a TDR
Palaniswamy P Tue, 04/24/2012 - 22:51
Hi Siva,
try to do this things:
1) clear the counter of interface gi0/13.
2) set the speed and duplex w.r.t hub
3)observe the ouputs of " show interface" (multiple time) .
4) After that if port not stabilizes then try to remove the pc one by one.
Palani
sivaalthi85 Wed, 04/25/2012 - 00:35
Hi This morning output,
Apr 25 08:21:33.546: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:21:35.560: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:21:39.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:21:43.495: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:21:46.733: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:21:48.746: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:22:00.675: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:22:02.688: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:22:26.403: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:22:28.416: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:23:29.787: DHCPD: checking for expired leases.
Apr 25 08:24:07.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:24:09.096: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:25:29.795: DHCPD: checking for expired leases.
Apr 25 08:26:52.037: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:26:54.050: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:27:29.802: DHCPD: checking for expired leases.
Apr 25 08:27:50.514: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:27:52.527: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:28:05.890: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:28:06.896: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to down
Apr 25 08:28:11.267: %LINK-3-UPDOWN: Interface GigabitEthernet0/13, changed state to up
Apr 25 08:28:11.267: DHCPD: interface GigabitEthernet0/13 coming up
Apr 25 08:28:12.274: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:29:29.809: DHCPD: checking for expired leases.
Apr 25 08:29:35.254: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:29:37.267: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:29:44.137: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:29:46.150: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:28.651: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:29.817: DHCPD: checking for expired leases.
Apr 25 08:31:30.673: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:33.072: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:35.077: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:39.942: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:41.955: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:31:52.189: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:31:54.203: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Apr 25 08:33:09.557: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to down
Apr 25 08:33:11.571: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/13, changed state to up
Harca_Teviot_Core#
mohseen patel Wed, 04/25/2012 - 01:54
Hi sivaalthi,
Can  please tell the model number of switch and hub.
Br.
Mohseen
sivaalthi85 Wed, 04/25/2012 - 02:48
HI Mohseen,
Its a layer 3 cisco switch and full duplex hub.
Leo Laohoo Wed, 04/25/2012 - 03:12
  • Hall of Fame,
    2017 LAN, Wireless
C'mon here.  Mohseen asked a very legitimate question.  Please answer appropriately.
I have the strange feeling this is a layer 1 issue.  One way of checking is TDR.
sivaalthi85 Wed, 04/25/2012 - 03:24
Sorry Its 3560
*    1 30    WS-C3560X-24P      12.2(53)SE2           C3560E-UNIVERSALK9-M
Leo Laohoo Wed, 04/25/2012 - 03:42
  • Hall of Fame,
    2017 LAN, Wireless
Ok. That's good. 3560X supports TDR.
1. Command: test cabl TDR int gig 0/13;
2. Wait between 5 to 7 seconds;
3. Command: sh cable TDR int gig 0/13;
4. Please post the output.
sivaalthi85 Wed, 04/25/2012 - 03:48
HI Leolaohoo,
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/13    100M  Pair A     N/A                N/A         Not Completed
                Pair B     N/A                N/A         Not Completed
                Pair C     N/A                N/A         Not Completed
                Pair D     N/A                N/A         Not Completed
Above is the output
Correct Answer
Leo Laohoo Wed, 04/25/2012 - 03:56
  • Hall of Fame,
    2017 LAN, Wireless
