WLC 5508 to a 4402 anchor
Answered Question
Apr 24th, 2012
Hello all-
We are deploying two 5508 WLC running 7.2 ios. Is it possible to anchor these to a 4402 running 7.0.116.0. Is there any version mismatch issues. We can find documents on the older compatibility but not on the new code.
Correct Answer by George Stefanick about 5 years 1 month ago
This actually just came up on another thread. I dont think its documented yet, but another user commented that its working on his install. I havent tested it myself.
Overall Rating: 4 (3 ratings)
Correct Answer
George Stefanick Tue, 04/24/2012 - 09:54
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
wesleyterry Tue, 04/24/2012 - 13:25
  • Bronze, 100 points or more
Historically, the Anchoring in Inter-Release Controller Mobility (IRCM) is the most tolerant of mobility features regarding code versions.  I've not seen an updated IRCM chart for 7.2,  but Anchoring is the one supported pretty much between 4.2 up to 7.0.....   I would expect that 7.0 to 7.2 would also fully function and be supported, especially since there would be alot of rumbling out there during customer migrations if people were really facing interoperability problems....
Now 7.2 to 4.2 and vice versa... thats probably more of a grey area...
George Stefanick Tue, 04/24/2012 - 13:33
Mr Wesley, Nice to see you on the forums as yourself! +5
Tommy Johnston Wed, 05/02/2012 - 10:41
George thanks for your help.....I tried to give it five stars but can not figure out how to change it.....
Tommy Johnston Tue, 04/24/2012 - 14:53
Thank you both for your reply. I will let you know how it goes.
Tommy Johnston Wed, 05/02/2012 - 10:43
There are no issues with anchoring with the 7.2 to 7.0116 in our deploymen.
Thanks for the help
George Stefanick Wed, 05/02/2012 - 12:35
Tommy,
Have you tested it ? Is it working?
Tommy Johnston Wed, 05/02/2012 - 12:39
Tested it with two 5508. The anchor on 7.0.116 the foreign on 7.2. No problems
Tommy
Scott Fella Thu, 05/03/2012 - 04:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I have some installs where I have 5508's running 7.2 and the customer used existing 4400's as an anchor, but running 7.0.230.0 with no issues.
Trending Topics - Security & Network
