5505 Inside Interface To Another Switch
Answered Question
Apr 24th, 2012
I am connecting the inside interface to an upstream switch and therefore will need to assign a static IP address to the inside address as I did below:
#sho int ip brief
Vlan1                      123.123.123.123  YES manual up                    up
I will also use this to manage the ASA. I am having a problem with the network configuration of the inside interface as I can't ping the gateway and/or the in IP of the inside interface.
Do I need to add any routes?
or
Am I forgetting some other steps?
Correct Answer by varrao about 4 years 11 months ago
Yes that's correct, if the host is not in the same network as the ASA inside interface, then you would definitely need a route for the next hop through which that network is reachable.
Varun
Correct Answer by mvsheik123 about 4 years 11 months ago
Do you have route to 123.123.123.123 from the management PC? Check if Vlan may be the issue(inter vlan communication in case of different vlan).
Also, ASA need to know how to get back to your management PC subnet (you need to add Static route or use IGP)
Thx
MS
Overall Rating: 5 (2 ratings)
Correct Answer
mvsheik123 Tue, 04/24/2012 - 18:01
  • Gold, 750 points or more
Thx
MS
thehxman101 Wed, 04/25/2012 - 05:54
I think it's an ASA route issue. I have the following:
d*   0.0.0.0 0.0.0.0 [1/0] via xx.xx.xx.xx.1, outside
So I would need an inside static route to point to the GW correct?
How do I do that?
Correct Answer
varrao Wed, 04/25/2012 - 06:00
  • Red, 2250 points or more
Varun
