Warning message
ASA5505 boot issue
When my ASA5505 starts it loads into rommon. I enter "boot" and everything boots fine. How do I make that load by default whenever it starts. Does anyone have the correct command syntax to make that happen?
here is the output from the entire boot process.
CISCO SYSTEMS
Embedded BIOS Version 1.0(12)13 08/28/08 15:50:37.45
Low Memory: 632 KB
High Memory: 507 MB
PCI Device Table.
Bus Dev Func VendID DevID Class              Irq
00  01  00   1022   2080  Host Bridge
00  01  02   1022   2082  Chipset En/Decrypt 11
00  0C  00   1148   4320  Ethernet           11
00  0D  00   177D   0003  Network En/Decrypt 10
00  0F  00   1022   2090  ISA Bridge
00  0F  02   1022   2092  IDE Controller
00  0F  03   1022   2093  Audio              10
00  0F  04   1022   2094  Serial Bus         9
00  0F  05   1022   2095  Serial Bus         9
Evaluating BIOS Options ...
Launch BIOS Extension to setup ROMMON
Cisco Systems ROMMON Version (1.0(12)13) #0: Thu Aug 28 15:55:27 PDT 2008
Platform ASA5505
Ethernet0/0
MAC Address: 5057.a8ca.98bd
Link is UP
Use ? for help.
rommon #0> boot
Launching BootLoader...
Boot configuration file contains 1 entry.
Loading disk0:/asa825-k8.bin... Booting...
Platform ASA5505
Loading...
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
Starting check/repair pass.
Starting verification pass.
/dev/hda1: 170 files, 30256/62780 clusters
dosfsck(/dev/hda1) returned 0
Processor memory 383561728, Reserved memory: 62914560 (DSOs: 0 + kernel: 62914560)
Total SSMs found: 0
Total NICs found: 10
88E6095 rev 2 Gigabit Ethernet @ index 09 MAC: 0000.0003.0002
88E6095 rev 2 Ethernet @ index 08 MAC: 5057.a8ca.98bc
88E6095 rev 2 Ethernet @ index 07 MAC: 5057.a8ca.98bb
88E6095 rev 2 Ethernet @ index 06 MAC: 5057.a8ca.98ba
88E6095 rev 2 Ethernet @ index 05 MAC: 5057.a8ca.98b9
88E6095 rev 2 Ethernet @ index 04 MAC: 5057.a8ca.98b8
88E6095 rev 2 Ethernet @ index 03 MAC: 5057.a8ca.98b7
88E6095 rev 2 Ethernet @ index 02 MAC: 5057.a8ca.98b6
88E6095 rev 2 Ethernet @ index 01 MAC: 5057.a8ca.98b5
y88acs06 rev16 Gigabit Ethernet @ index 00 MAC: 5057.a8ca.98bd
Licensed features for this platform:
Maximum Physical Interfaces    : 8
VLANs                          : 3, DMZ Restricted
Inside Hosts                   : 10
Failover                       : Disabled
VPN-DES                        : Enabled
VPN-3DES-AES                   : Enabled
SSL VPN Peers                  : 2
Total VPN Peers                : 10
Dual ISPs                      : Disabled
VLAN Trunk Ports               : 0
Shared License                 : Disabled
AnyConnect for Mobile          : Disabled
AnyConnect for Cisco VPN Phone : Disabled
AnyConnect Essentials          : Disabled
Advanced Endpoint Assessment   : Disabled
UC Phone Proxy Sessions        : 2
Total UC Proxy Sessions        : 2
Botnet Traffic Filter          : Disabled
This platform has a Base license.
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
                             Boot microcode   : CN1000-MC-BOOT-2.00
                             SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
                             IPSec microcode  : CNlite-MC-IPSECm-MAIN-2.05
Cisco Adaptive Security Appliance Software Version 8.2(5)
  ****************************** Warning *******************************
  This product contains cryptographic features and is
  subject to United States and local country laws
  governing, import, export, transfer, and use.
  Delivery of Cisco cryptographic products does not
  imply third-party authority to import, export,
  distribute, or use encryption. Importers, exporters,
  distributors and users are responsible for compliance
  with U.S. and local country laws. By using this
  product you agree to comply with applicable laws and
  regulations. If you are unable to comply with U.S.
  and local laws, return the enclosed items immediately.
  A summary of U.S. laws governing Cisco cryptographic
  products may be found at:
  If you require further assistance please contact us by
  sending email to [email protected].
  ******************************* Warning *******************************
Copyright (c) 1996-2011 by Cisco Systems, Inc.
                Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
                Cisco Systems, Inc.
                170 West Tasman Drive
                San Jose, California 95134-1706
Cryptochecksum (unchanged): fb24433f 69d6434b bcd05613 3db1ccab
Type help or '?' for a list of available commands.
superbotasa5505>
