Warning message
Jabber through HTTP Proxy (Squid) ?
Apr 24th, 2012
How do I configure Jabber to access internet though a HTTP Proxy , like Squid ? By Default Jabber ignores the windows proxy configuration and it tries to connect https in direct mode ( I snnifed with my Wireshark such connection)
Martin Koch Sat, 05/05/2012 - 04:45
  • Red, 2250 points or more
If you are behind a network which require all communication to be piped through a http-proxy
it will not work anyhow as this is only the first stage of communication which is done to configure
the client.
The sip registration and the rtp media would then be the next problem and if you
can open them in your firewall it should also be possible to open https for this specific cisco ip.
Elter Picolo Mon, 03/28/2016 - 13:45
Hi guys,
do you know an alternative to send all flow/traffic from a Jabber for Windows 11.1 through a Proxy without to use a VPN?
The Expressway Edge have its public IP and the MRA configured. Everything fine from internet, but a specific country do not allow direct connections to internet. All internet traffic flow through Proxy.
Any ideas?
