show nat translation
Answered Question
Apr 24th, 2012
  • Silver, 250 points or more
i am using cisco asa 5510 with version 8.2(1)11
1-i can't find the command to display current NAT translations (local inside   local outside    global inside    global outside).
2- is it possible to change the timeout of NAT (is it 24h like in the router?)
thanks
Correct Answer by Julio Carvajal about 5 years 3 months ago
1-Show xlate
2- Yes, it is time-out xlate ( Default 3 hours)
Do rate all the helpful posts
Overall Rating: 5 (2 ratings)
Correct Answer
Julio Carvajal Tue, 04/24/2012 - 23:21
  • Purple, 4500 points or more
1-Show xlate
