Cisco 887 & Playstation3 - test connectivity failing.
Answered Question
Apr 25th, 2012
Hi Guys,
Having issue with 887 and ps3. Can get the internet connection via ps3 no problem , playstaion network, browse websites and so on but once I using feature on PS3  'test connectivity'  and run it. I'm loosing connection.
The 887(have latest IOS) and is connected via wire to ps3. I have assigned the static ip address on ps3 and open dns(4.2.2.2).
I know that cisco doesn't support UPnP , would that be related to it?
I have tried enable or disable the UPnP on the ps3 , still the same.
Have open all ports just for testing purpouses on the 887.
Annoying thing is that once I use some home user DSL modem , everything is working ok.(Can get online and once I do test connectivity , it works as well)..
Its tricky , any reason?
Luk.
Correct Answer by Paolo Bevilacqua about 1 year 12 months ago
Cisco IOS routers are not apt for home use, for that and other reasons.
Recommend you get a router from the "small business" line of products for that purpose.
Average Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Wed, 04/25/2012 - 05:00
sawickas07 Wed, 04/25/2012 - 05:10
Hi Paolo ,
Yes you are correct but I wanted to find out why it doesnt work..!! Maybe is a way to configure it properly.
Luk.
sawickas07 Mon, 04/30/2012 - 03:03
ok , sorted!
I knew it can be done.
I have enable the spanning tree portfast and the test connection on playstaion 3 not timing out anymore!
The test connectivity passes succesfully !!!!
ThanksLuk.
Login or Register to take actions
Posted April 25, 2012 at 3:20 AM
Stats:
Replies:3 Avg. Rating:5
Views:617 Votes:0
Shares:0
Categories: Switches, IP SLA
Related Content
Discussions Leaderboard
Rank Username Points
1 15,007
2 8,155
3 7,745
4 7,088
5 6,742
140
80
78
64
40
