Remote VPN User Changing Password When Connecting via Cisco Anyconnect
Apr 25th, 2012
Hi All,
I have setup a VPN connection using Cisco Anyconnect with Cisco 5505 and Cisco ACS v5.3. I have created the VPN inside the ACS and I wish to force the user to change the password on their first login. However, the Anyconnect client is not able to force the user to change the password even though I have check the option for the user to change password on first login when I create the user in the ACS. Is there any setting that I will need to configure?
On top of that, I have also read that the changing of the password for the VPN can be achieve with Cisco Anyconnect and a LDAP. Please advice. Please refer to the link below.
https://supportforums.cisco.com/docs/DOC-1361#Q_Can_AnyConnect_or_Clientless_SSL_VPN_users_initiate_passwordmanagementchanges_from_the_AnyConnect_client_itself
Thks and Rgds
