Warning message
shape average percent on different devices
Apr 25th, 2012
Hello all,
I have set QoS up over many tunnel wan connections.  My problem:  Most of my tunnels are point-to-point wireless bridges that vary in bandwidth depending on the quality and distance of the shot.  To apply QoS to these interfaces at different bandwidths, I have to create multiple policy-maps on some devices.  I have two 3845s, one allows shape average percent on tunnels, the other does not. One running 15.0(1)M2and the other is 15.0(1)M3 IOS.  I have not been able to find why certain devices do not allow bandwidth percentages. I also can apply it to most of my 3825s, but not all.
Sample QoS configuration
class-map match-any VOICE-SIGNALING
match  dscp cs3
match  dscp af31
class-map match-all ROUTING-PROTOCOLS
match  dscp cs6
class-map match-all GOLD
match access-group name GOLD
class-map match-all GOLD-VOICE
match  dscp ef
class-map match-any SILVER-VOICE
match  dscp ef
policy-map QUEUEING-TO-WAN
class GOLD-VOICE
   priority percent 10
class SILVER-VOICE
   priority percent 5
class VOICE-SIGNALING
   bandwidth remaining percent 4
   set dscp ef
class GOLD
   bandwidth remaining percent 50
class class-default
   fair-queue
policy-map SHAPING-TO-WAN
class class-default
   shape average percent 99
   service-policy QUEUEING-TO-WAN
interface Tunnel100
description *** SAMPLE TUNNEL ***
bandwidth 8192
ip address 10.10.10.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu XXXX
ip tcp adjust-mss XXXX
load-interval 30
delay 100
qos pre-classify
tunnel source Serial0/2/1
tunnel destination 172.16.5.1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SECURE
service-policy output SHAPING-TO-WAN
end
Jacob Jennings Wed, 04/25/2012 - 05:20
I just checked again, I also cannot apply shape average percent to a 3845 running 15.0(1)M2.
Joseph W. Doherty Wed, 04/25/2012 - 10:09
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You likely answered you're own question, i.e. a feature unique to a later IOS version.  (I wasn't even aware this could be done, but then I have worked with any 15.x IOSs.)
PS:
Might be a good idea to add tunnel path-mtu-discovery to your tunnel interfaces and you shouldn't need qos pre-classify (unless your doing QoS on the physical interface too and you need to examine pre-tunnel IP header info).
Jacob Jennings Thu, 04/26/2012 - 02:58
I agree with you about the IOS version, but why can I do it on a 3825 running 12.4.  I guess I just wanted to know when it was implemented and why it works on some routers.  It seems sporadic.
Related Content
