eBGP using admin distance 200?
Answered Question
Apr 25th, 2012
#sh ip protocols | begin bgp
Routing Protocol is "bgp 65005"
  Outgoing update filter list for all interfaces is not set
  Incoming update filter list for all interfaces is not set
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    15.15.12.5                                          LOCAL_PREF
    15.15.13.5                                          LOCAL_PREF
    10.24.35.12
  Maximum path: 1
  Routing Information Sources:
    Gateway         Distance      Last Update
    15.15.12.5          20           3d07h
   15.15.13.5         200          3d08h                                            <<<<<<<<<<<<<why is the admin distance 200? This is my ebgp peer?
    10.24.35.12        200          3d07h
  Distance: external 20 internal 200 local 200
#sh ip bgp summary | begin Neighbor
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
15.15.12.5    4          152 1835547 1963240     5854    0    0 45w3d          39
15.15.13.5    4          152   28627   30410     5854    0    0 4d22h          39 <<<<<<<<<<<<<<<<<<<<<<ebgp
10.24.35.12    4        65005  662657  662384     5854    0    0 1y7w           48
router bgp 65005
neighbor 15.15.13.5 remote-as 152 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<ebgp
So why am I getting eBGP distance 200 for 15.15.13.5 when I use #sh ip protocols | begin bgp????
Correct Answer by John Blakley about 5 years 2 months ago
Can you post these policy maps?
LOCAL_PREF
And can you post (masking public addresses) the bgp config?
Overall Rating: 5 (1 ratings)
John Blakley Wed, 04/25/2012 - 06:43
  • Purple, 4500 points or more
Can you post "sh ip bgp neigh 15.15.13.5"?
kunal-united Wed, 04/25/2012 - 06:50
  here you go
#sh ip bgp neighbors 15.15.13.5
BGP neighbor is 15.15.13.5,  remote AS 152, external link
Description: Telus MPLS Secondary Peer
  BGP version 4, remote router ID 24.25.24.181
  BGP state = Established, up for 4d22h
  Last read 00:00:00, last write 00:00:10, hold time is 45, keepalive interval is 15 seconds
  Configured hold time is 45, keepalive interval is 15 seconds
  Minimum holdtime from neighbor is 0 seconds
  Neighbor sessions:
    1 active, is not multisession capable
  Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised
    Address family IPv4 Unicast: advertised and received
    Multisession Capability: advertised
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:               49        248
    Keepalives:         30417      28438
    Route Refresh:          7          0
    Total:              30474      28687
  Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
  Session: 15.15.13.5
  BGP table version 5854, neighbor version 5854/0
  Output queue size : 0
  Index 6
  6 update-group member
  Inbound path policy configured
  Incoming update prefix filter list is ACCEPTED_NETS
  Outgoing update prefix filter list is ADVERTIZED_NETS
  Route map for incoming advertisements is LOCAL_PREF
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:               4         39 (Consumes 2028 bytes)
    Prefixes Total:                27        322
    Implicit Withdraw:             22        276
    Explicit Withdraw:              0          7
    Used as bestpath:             n/a          0
    Used as multipath:            n/a          0
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    prefix-list                         273        178
    Bestpath from this peer:              3        n/a
    Invalid Path:                         8        n/a
    Total:                              284        178
  Number of NLRIs in the update sent: max 10, min 0
  Address tracking is enabled, the RIB does have a route to 15.15.13.5
  Connections established 2; dropped 1
  Last reset 4d22h, due to BGP Notification received of session 1, hold time expired
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: 15.15.13.6, Local port: 61462
Foreign host: 15.15.13.5, Foreign port: 179
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0x8607CA760):
Timer          Starts    Wakeups            Next
Retrans         30478         43             0x0
TimeWait            0          0             0x0
AckHold         28514      27740             0x0
SendWnd             0          0             0x0
KeepAlive           0          0             0x0
GiveUp              0          0             0x0
PmtuAger            1          1             0x0
DeadWait            0          0             0x0
Linger              0          0             0x0
ProcessQ            0          0             0x0
iss: 2947749338  snduna: 2948329445  sndnxt: 2948329445     sndwnd:  15339
irs:   56652898  rcvnxt:   57208441  rcvwnd:      15814  delrcvwnd:    570
SRTT: 300 ms, RTTO: 303 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 0 ms, maxRTT: 340 ms, ACK hold: 200 ms
Status Flags: active open
Option Flags: nagle, path mtu capable, md5
IP Precedence value : 6
Datagrams (max data segment is 1440 bytes):
Rcvd: 58571 (out of order: 0), with data: 28520, total data bytes: 555542
Sent: 58561 (retransmit: 43, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 30436, total data bytes: 580106
Packets received in fast path: 0, fast processed: 0, slow path: 0
fast lock acquisition failures: 0, slow path: 0
Correct Answer
John Blakley Wed, 04/25/2012 - 07:04
LOCAL_PREF
kunal-united Wed, 04/25/2012 - 07:16
router bgp 65005
no synchronization
bgp log-neighbor-changes
neighbor 15.15.12.xxx5 remote-as 152
neighbor 15.15.12.xxx5 timers 15 45
neighbor 15.15.12.xxx5 prefix-list ACCEPTED_NETS in
neighbor 15.15.12.xxx5 route-map LOCAL_PREF in
neighbor 15.15.13.xxx5 remote-as 152
neighbor 15.15.13.xxx5 timers 15 45
neighbor 15.15.13.xxx5 prefix-list ACCEPTED_NETS in
neighbor 15.15.13.xxx5 route-map LOCAL_PREF in
neighbor 10.24.35.12 remote-as 65005
neighbor 10.24.35.12 next-hop-self
no auto-summary
#sh route-map
route-map LOCAL_PREF, permit, sequence 10
  Match clauses:
  Set clauses:
    local-preference 80
  Policy routing matches: 0 packets, 0 bytes
route-map LOCAL_PREF, permit, sequence 20
  Match clauses:
  Set clauses:
The public ip's and AS# are all false.
John Blakley Wed, 04/25/2012 - 07:21
I don't see anything that jumps out as the reason that you're getting that. It's treating this neighbor as iBGP it seems (AD-wise anyway). Can you post "sh ip bgp "?
So if the route 192.168.1.0 goes through this neighbor, post "sh ip bgp 192.168.1.0" and "sh ip bgp regex ^152"
kunal-united Wed, 04/25/2012 - 07:30
Can "administrative distance" get injected by the Service provider?
John Blakley Wed, 04/25/2012 - 07:34
No that's locally generated. They can change the metric that you receive though.
kunal-united Wed, 04/25/2012 - 07:39
Could it be that the ISP is using "BGP backdoor"?
If I dont have anything in my configuration then it looks like the ISP is doing something?
Please advise.
John Blakley Wed, 04/25/2012 - 07:45
A backdoor allows a route from another routing protocol with a higher distance to be used instead of the lower AD from eBGP. In other words, it allows say EIGRP learned route of 192.168.1.0/24 and eBGP learned route of 192.168.1.0/24 to use the EIGRP learned route instead of the eBGP learned one.
kunal-united Wed, 04/25/2012 - 07:46
I got it ....It is actually the ISP set it on their side and I am seeing it.
It is not what I set ...I still treat it as 20.
Thanks for looking into it
