Warning message
Interface vfc, vsan is going down
Apr 25th, 2012
I have some logs in Nexus 5k that I didn't found in anywhere and would like to know what this means
2012 Apr  1 02:16:40 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc40, vsan 2001 is down (waiting for flogi)
2012 Apr  1 02:17:11 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc40, vsan 2001 is down (Initializing)
2012 Apr  1 02:17:11 TJERJ481 %PORT-5-IF_TRUNK_UP: %$VSAN 2001%$ Interface vfc40, vsan 2001 is up
2012 Apr 10 13:03:29 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc39, vsan 2001 is down (waiting for flogi)
2012 Apr 10 13:03:59 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc39, vsan 2001 is down (Initializing)
2012 Apr 10 13:03:59 TJERJ481 %PORT-5-IF_TRUNK_UP: %$VSAN 2001%$ Interface vfc39, vsan 2001 is up
2012 Apr 18 13:24:27 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc40, vsan 2001 is down (waiting for flogi)
2012 Apr 18 13:24:57 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc40, vsan 2001 is down (Initializing)
2012 Apr 18 13:24:57 TJERJ481 %PORT-5-IF_TRUNK_UP: %$VSAN 2001%$ Interface vfc40, vsan 2001 is up
2012 Apr 20 18:58:50 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc35, vsan 2001 is down (waiting for flogi)
2012 Apr 20 18:59:20 TJERJ481 %PORT-5-IF_TRUNK_DOWN: %$VSAN 2001%$ Interface vfc35, vsan 2001 is down (Initializing)
2012 Apr 20 18:59:20 TJERJ481 %PORT-5-IF_TRUNK_UP: %$VSAN 2001%$ Interface vfc35, vsan 2001 is up
As we can see, the dates and interfaces are random when it goin down. Apparently I don't have any problem with access my storage when this logs occurs.
Below the configurations about these interfaces :
interface vfc35
  bind interface Ethernet1/35
  no shutdown
interface vfc39
  bind interface Ethernet1/39
  no shutdown
interface vfc40
  bind interface Ethernet1/40
  no shutdown
  switchport mode trunk
  switchport trunk allowed vlan 2001
  duplex full
  spanning-tree port type edge trunk
  duplex full
sh vsan 2001
vsan 2001 information
         name:VSAN2001  state:active
         interoperability mode:default
         loadbalancing:src-id/dst-id/oxid
         operational state:up
Someone can help me?!
Fábio Henrique Teixeira
Prashanth Krishnappa Wed, 04/25/2012 - 09:32
  • Cisco Employee,
What kind of CNAs do you have? The message  means the switch is waiting for FLOGI. Most common reason for a vFC to flap is missing FIP Keep-alive causing the interface to go down and then waiting for FLOGI.
But you can collect following outputs to see if there is anything pointing to the problem
show platform software fcoe_mgr info interface vfc x
show platform software fcoe_mgr event-history errors
Trending Topics: Storage Networking
