Cisco 7204 VXR NPE-G1 support MPLS
n.taka
We just bought a Cisco 7204 VXR NPE-G1 with IOS
c7200-is-mz.123-15b.bin.
I would like to configure it for our MPLS lab router, can I upgrade this router to support MPLS protocol.
Please need your assistance.
regards
Navi
10 Replies 10
Ivan Krimmel
Level 7
Level 7
hi Navi,
you might use http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp for these queries in the future, 12.3-15b does support MPLS as well, you just need SERVICE PROVIDER feature set.
HTH!
Hi Ivan,
Thanks for your response.
OK, the Cisco tool is a little bit hard to get.
What I requested for is that…..Can the Cisco 7204 NPE-G1 upgradeable to support MPLS? (the current IOS is this router Cisco 7204 router is C7200-is-mz.123-15b.bin
Navi
Hi Navi,
yes it can, platform-wise, you just need a proper IOS image for that. What do you have in 'sh ver' at the moment?
Hi Iavn
Below is the sh version
Router#sh version
IOS (tm) 7200 Software (C7200-IS-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Thu 25-Aug-05 19:08 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61CB8000
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(15b), RELEASE SOFTWARE (fc1)
Router uptime is 4 hours, 55 minutes
System image file is "disk2:c7200-is-mz.123-15b.bin"
cisco 7204VXR (NPE-G1) processor (revision C) with 491520K/32768K bytes of memory.
Processor board ID 30882615
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
4 slot VXR midplane, Version 2.8
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port
Adaptor Hardware Configuration Guidelines" on CCO ,
for c7200 bandwidth points oversubscription/usage guidelines.
3 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
navi
Right, it is an IP PLUS image, you would need this:
c7200-p-mz.123-15b.bin
to run MPLS.
Thanks….
I have an existing 7206 NPE-G2 router with sh version below. Can I upgrade the 7204 IP Plus image to the 7206 NPE-G2 image?
Cisco IOS Software, 7200 Software (C7200P-SPSERVICESK9-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 26-Feb-09 01:45 by prod_rel_team
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(24)T, RELEASE SOFTWARE (fc1)
SUV-IP-RTR-ER01 uptime is 2 years, 33 weeks, 3 days, 34 minutes
System returned to ROM by reload at 08:03:24 FJT Sun Sep 6 2009
System restarted at 08:13:41 FJST Sun Sep 6 2009
System image file is "disk2:c7200p-spservicesk9-mz.124-24.T.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 36575575
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Hi Ivan,
How can I get this image?
Navi,
if you mean "NPE-G2" image, then it is not possible 'cause it is a different CPU type, not image. In other words if you wish upgrade from NPE-G1 to NPE-G2, you need to change hardware rather than software.
I hope this is clear now.
Cheers!
Thanks Ivan,
It’s clear now.
Do you have any idea of where we can get the below IOS from? I notice that the NPE-G1 is not supported with Cisco anymore.
Navi
