Comcast connection on E4200
Apr 25th, 2012
For those of you who are trying to connect your router to a Comcast modem, be sure to actually RESET the modem instead of just depowering it like it instructs you in the setup process. This should save a lot of trial and error.  Also unmark the MAC address cloning like the Cisco connect software does, then just renew IP and it should connect just fine.
