Warning message
How to Manage the Traffic between the Firewall & Switch ?
Apr 25th, 2012
I have a setup where the Client Network is connected to a Firewall and it is being managed by the client. That firewall is connected to my Network also.
As it is connected to my network also i don't have any control to view the Traffic hitting my network from the Client Network.
Is there any way i can control the traffic from the Firewall at the Switch where the Firewall is connected.
Or is there any Linux box i can connect to restrict the traffic which is hitting my network from the Client.
Attached a Simple block  diagram for your reference. Kindly help.
GanAlagu07
Maykol Rojas Wed, 05/02/2012 - 21:07
  • Cisco Employee,
  • Participante Destacado,
    Mejor Publicación, Diciembre del 2015
Ganesh,
You can put a SPAN on the switch and check the traffic arriving to your network and then Apply Vlan filter to filter the traffic entering your network.
Mike.
