Does anyone have a sample of AXL script for CUCM 8.6 to bulk add route-patterns?
Answered Question
Apr 25th, 2012
So sad, need to configure over 500 route patterns.
Need something like this, but for route-pattern.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xm
lns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org
/2001/XMLSchema">
<SOAP-ENV:Body>
<addRouteGroup>
<routeGroup>
<name>RG-ICT-FMPREPROD-AMRSS
</name>
<dialPlanWizardGenId>0</dialPlanWizardGenId>
<members>
<deviceSelectionOrder>1</deviceSelectionOrder>
<deviceName></deviceName>
</members>
</routeGroup>
</addRouteGroup>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Thanx in advance!
Correct Answer by Ayodeji Okanlawon about 5 years 1 month ago
If you dont get AXL script, try import/export..Export an existing RP from CUCM or configure just one. and then edit it and add to it. Then Import it back. It works great!
Overall Rating: 5 (1 ratings)
Correct Answer
Ayodeji Okanlawon Wed, 04/25/2012 - 23:40
  • Cisco Designated VIP,
    2017 IP Telephony
Gordon Ross Thu, 04/26/2012 - 00:15
  • Blue, 1500 points or more
You're probably better off asking over in the developer forums for AXL queries.
If you want, you could probably reverse engineer the AXL SOAP query from the WSDL.
I tend to just you SQL INSERT/UPDATEs, rather than the SOAP functions.
GTG
Aaron Harrison Thu, 04/26/2012 - 00:57
  • Community Spotlight Award,
    Member's Choice, May 2015
Yeah - if you're a developer, check the developer.cisco.com website and the forums there.
If you are not a developer you would be better off using the export function to export a 'template' route pattern you have configured manually, then copy/editing that in the exported file before importing it again.
Aaron
Frederick Nielsen Thu, 04/26/2012 - 06:33
  • Bronze, 100 points or more
Like this, but you will definitely want to investigate the schema def if you haven't already, and agree with the others, if you are in the dev program that forum can be very helpful:
911
Emergency Services (Urgent)
LA-EMERGENCY-PT
false
true
true
PSTN-LRG-RL
Ayodeji Okanlawon Wed, 05/16/2012 - 14:35
    2017 IP Telephony
You are welcome..It has worked wonders for me. Thanks for the nice rating
Dennis Mink Wed, 05/16/2012 - 17:03
500 RP's is a lot, are you using Standard Local Route Groups at all?
