WLAN Controller / 1131AG AP
Apr 26th, 2012
I have just purchased a WLAN 2112 controller and some new AP's.
I have successfully connected the AP with the controller and it gets the profile settings fine.
However after every reboot , Radio does not come up automatically and I have to manually connect and issue the no shutdown command.
Obvioulsy this is no good , especially when I configure another 6 or 7.
Does anyone have idea on this?
Cheers
Average Rating: 5 (2 ratings)
LBSNEWCASTLE Thu, 04/26/2012 - 04:05
Im still testing so only have the one configured at the moment , and yes if I reboot it , I have to telnet and do "no shutdown" on the radio interfaces.
LBSNEWCASTLE Thu, 04/26/2012 - 04:10
lightweight AP.
I realise it should all be configured via the controller. That is my question really, how do I make sure the radio comes back up after power cycle?
Many thanks
nikhilcherian Thu, 04/26/2012 - 04:12
Have you enabled the telnet on the AP from the controller.
Are you connecting the AP directly to the controller or through the switch
nikhilcherian Thu, 04/26/2012 - 04:18
Hope the switch is able to supply the sufficient power levels and the regulatory domain is same on both the AP and the WLC
LBSNEWCASTLE Thu, 04/26/2012 - 04:24
The AP is not using POE. It has its own power adapter.
And if the regulatory domains were different I dont think the AP would join the Controller in the first place.
LBSNEWCASTLE Thu, 04/26/2012 - 04:59
did that, but still get this.
eset
*Jan 11 22:34:12.987: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Jan 11 22:34:13.099: Logging LWAPP message to 255.255.255.255.
*Jan 11 22:34:13.142: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.
255 started - CLI initiated
*Jan 11 22:34:33.931: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 26 12:53:17.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 10.221.168.26 peer_port: 5246
*Apr 26 12:53:18.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Apr 26 12:53:19.655: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
peer_ip: 10.221.168.26 peer_port: 5246
*Apr 26 12:53:19.657: %CAPWAP-5-SENDJOIN: sending Join Request to 10.221.168.26
*Apr 26 12:53:19.657: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Apr 26 12:53:19.775: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Apr 26 12:53:20.065: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Apr 26 12:53:20.080: %CAPWAP-5-CHANGED: CAPWAP changed state to UP
*Apr 26 12:53:20.080: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Apr 26 12:53:20.082: %CAPWAP-5-JOINEDCONTROLLER: AP has joined controller Cisco
_f6:7f:30
*Apr 26 12:53:20.134: %LWAPP-3-CLIENTEVENTLOG: SSID NCLGUEST added to the slot[0
*Apr 26 12:53:20.137: %LWAPP-3-CLIENTEVENTLOG: SSID NCLGUEST added to the slot[1
*Apr 26 12:53:20.153: %WIDS-6-ENABLED: IDS Signature is loaded and enabled
*Apr 26 12:53:21.066: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
*Apr 26 12:53:21.081: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
nikhilcherian Thu, 04/26/2012 - 05:05
can you please post the output of
"show country" from WLC and  " show controller d0 and show controllers d1 " from the AP
LBSNEWCASTLE Thu, 04/26/2012 - 05:13
(Cisco Controller) >show country
Configured Country............................. GB  - United Kingdom
Configured Country Codes
        GB  - United Kingdom............................ 802.11a Indoor,Outdoor / 802.11b / 802.11g
interface Dot11Radio0
Radio AIR-AP1131G, Base Address 003a.9a3d.f540, BBlock version 0.00, Software version 6.30.14
Serial number: GAM15497KCD
Number of supported simultaneous BSSID on Dot11Radio0: 16
Carrier Set: EMEA (EU) (-E)
Uniform Spreading Required: No
Configured Frequency: 2462 MHz  Channel 11
Allowed Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13)
Listen Frequencies: 2412(1) 2417(2) 2422(3) 2427(4) 2432(5) 2437(6) 2442(7) 2447(8) 2452(9) 2457(10) 2462(11) 2467(12) 2472(13) 2484(14)
Beacon Flags: 0, Interface Flags 60109, Interface Events 0, Mode 9; Beacons are disabled; Probes are disabled
High Density mode disabled
  Local Rx sensitivity (Config -80, Max -60, Min -11) dBm
        CCA Sensitivity -60 dBm
  Cell  Rx sensitivity -80 dBm, CCA Sensitivity -60 dBm
Configured CCK Power: 14 dBm (level 1)
Configured OFDM Power: 14 dBm
Active power levels by rate
     1.0 to 54.0  , 14  dBm
  OffChnl Power: 14, Rate 1.0
Allowed CCK Power Levels:  -1 2 5 8 11 14
Allowed OFDM Power Levels: -1 2 5 8 11 14
Allowed Client Power Levels: 2 5 8 11 14
Receive Antennas : right-a left-b
Transmit Antennas : right-a left-b
Antenna: internal, Gain: Allowed 8, Reported 8, In Use 8
Active Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Current Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0
Allowed Rates:  1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates:  1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Default Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Range Rates:  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Throughput Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
Current Voice Rates:  basic-5.5 basic-11.0 6.0 12.0 24.0 [disabled until voice packet-discard enabled]
Default Voice Rates:  basic-5.5 basic-11.0 6.0 12.0 24.0
Managment Rates:  basic-1.0
Multicast Rates:  basic-1.0 basic-2.0 basic-5.5 basic-11.0
Data Rate Sensitivity (rate, SNR dB, Contention dBm)
( 1.0, 10, -93)   ( 2.0, 10, -92)   ( 5.5, 11, -90)   (11.0, 14, -90)
( 6.0, 15, -89)   ( 9.0, 16, -88)   (12.0, 18, -88)   (18.0, 19, -86)
(24.0, 20, -85)   (36.0, 24, -81)   (48.0, 27, -78)   (54.0, 31, -77)
ERP settings: short slot time.
Neighbors in non-erp mode:
Number of MFP Indices: 10
RFID Tag Detection: Enabled
Multicast Address filtered:   010b.8500.0000  0140.9600.0004  010c.cc00.0000  0114.7e00.0000  0140.9600.0003
Packet type filtered:
Probe limit: active off, filter on, count 0, time 0
Assoc limit: active off, count 25, time 500000
Radio Management (RM) Configuration: Regular AP, Mode 1, Disabled
MCST RSCs: [0]0x0 [1]0x0 [2]0x0 [3]0x0 [4]0x0
TKIP Cum Stats: STA            MIC-L-Errs MIC-R-Errs Replay   C-Measure
                0000.0000.0000 00000000   00000000   00000000 00000000
AES-CCMP Cum Stats: 00000000 replays discarded
QBSS Load: 0x7B, Policing Stats: Rx downgrades 0, Tx downgrades 0
Classifier Stats tx_on_up6  0, tx_on_up4 0
Configured Local Access Class Parameters
  Back      : cw-min 4 cw-max 10 fixed-slot 7 admission-control Off txop 0
  Best      : cw-min 5 cw-max 10 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 4 cw-max 5 fixed-slot 2 admission-control Off txop 0
  Voice     : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 0
SIP stats sip_udp_rx_pkt 0, sip_tcp_rx_pkt 0,
                            downlink classified_pkt 0,
                            uplink classified_pkt 0,
                            num_processed_SIP_Calls 0
interface Dot11Radio1
Radio AIR-AP1131A, Base Address 003a.9a36.2e70, BBlock version 0.00, Software version 6.30.14
Serial number: ALP15497KCD
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: ETSI (OFDM) (EU) (-E)
Uniform Spreading Required: Yes
Configured Frequency: 5320 MHz  Channel 64 (DFS enabled)
Allowed Frequencies: 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(60) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5660(132) 5680(136) 5700(140)
Listen Frequencies: 5170(34) 5190(38) 5210(42) 5230(46) 5180(36) 5200(40) 5220(44) 5240(48) 5260(52) 5280(56) 5300(60) 5320(64) 5500(100) 5520(104) 5540(108) 5560(112) 5580(116) 5600(120) 5620(124) 5640(128) 5660(132) 5680(136) 5700(140) 5745(149) 5765(153) 5785(157) 5805(161) 5825(165)
  Local Rx sensitivity (Config -80, Max -57, Min -17) dBm
Configured Power: 17 dBm (level 1)
     6.0 to 54.0  , 17  dBm
  OffChnl Power: 17, Rate 6.0
Allowed Power Levels:  -1 2 5 8 11 14 15 17
Allowed Client Power Levels: 2 5 8 11 14 15 17
Active Rates:  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
Current Rates:  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
Allowed Rates:  6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
All Rates:  6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Default Rates:  basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
Best Range Rates:  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Best Throughput Rates:  basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
Current Voice Rates:  basic-6.0 basic-12.0 basic-24.0 [disabled until voice packet-discard enabled]
Default Voice Rates:  basic-6.0 basic-12.0 basic-24.0
Managment Rates:  basic-6.0
Multicast Rates:  basic-6.0 basic-12.0 basic-24.0
QBSS Load: 0x0, Policing Stats: Rx downgrades 0, Tx downgrades 0
  Best      : cw-min 4 cw-max 10 fixed-slot 3 admission-control Off txop 0
  Video     : cw-min 3 cw-max 4 fixed-slot 2 admission-control Off txop 0
  Voice     : cw-min 2 cw-max 3 fixed-slot 2 admission-control Off txop 0
nikhilcherian Thu, 04/26/2012 - 05:59
This looks to be quite fine, by any chance did u try with another AP/power injector
Stephen Rodriguez Thu, 04/26/2012 - 06:15
really dumb question, but you have the 802.11b/g/n and a/n networks enabled globally on the WLC correct?
If you go into Wireles, then on the Right side, choose the 802.11a/n, pick the AP, can you enable/disable the radio from there?
What firmware are you running on the WLC?
Steve
nikhilcherian Thu, 04/26/2012 - 04:02
Can you elaborate when you say you have to do manual no shutdown. Do you console into each lightweight AP and issue the command
Leo Laohoo Sat, 04/28/2012 - 06:06
I'm with Steve here. Sounds like the WLC radio is globally disabled.
Amjad Abdullah Sun, 04/29/2012 - 02:28
Agree,
you need to check radios ststus from WLC and make sure they are up first.
LBSNEWCASTLE Mon, 04/30/2012 - 01:32
Thanks for the input.
The radio staus is as below, showing admin status enable but operational status DOWN.
I havent tried another AP but will as soon as I get a chance.
AP NameRadio Slot#Base Radio MACAdmin StatusOperational StatusChannelPower LevelAntenna
Radio Slot#Radio Interface TypeSub BandAdmin StatusOper StatusRegulatory Domain
LBSNEWCASTLE Mon, 04/30/2012 - 01:43
So this is what shows in Radio settings after AP has been rebooted.
Radio Slot#        Base Radio MAC     Admin Status     Operational Status        Channel    Power Level       Antenna
0                                                     Enable               DOWN                        1*             1*                     Internal
nikhilcherian Mon, 04/30/2012 - 03:19
Please posts these outpus also
show ap config 802.11a summary
show ap config 802.11b summary
Amjad Abdullah Mon, 04/30/2012 - 03:12
Hey: were are you getting this output from? this is not from WLC, is it?
if the admin status is up but the operation status is downt his is high likely a power issue.
Because you are using power supply, not PoE, I think your power supply does not provide enough power to the AP.
Try using PoE or Power Injector instead. if you are using a power injector and not a power supply, try to provide the power injector information in Wireless-> AP name -> Advanced -> Powr Over Ethernet Settings.
Try different power options to make sure it is not a power issue. radios usually go down if there are no enough power. it seems your power source is either faulty or not for this AP model.
You can also check the trap log (from cli "show traplog" or from GUI : Management-> SNMP -> Trap Logs.) there will be trap messages if the issue is related to the power. connect the AP and monitor the traplog if any indication about a power problem.
you can also check this post: https://supportforums.cisco.com/thread/342250
Amjad
LBSNEWCASTLE Mon, 04/30/2012 - 05:39
Thanks everyone and apologies for wasting your time.
I have tried another AP and worked fine, so the first one out of 7 new boxed AP's I picked is faulty.. doh!
Login or Register to take actions
Posted April 26, 2012 at 3:06 AM
Stats:
Replies:26 Avg. Rating:5
Views:1531 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
