ACE 4710 - IDS messages
Apr 26th, 2012
I've got logging turned up to 5 at present on some ACE 4710's and the logs are filled with messages: -
   Error Message %ACE-4-400000: IDS:1000 IP Option Bad Option List from a.b.c.d
Which according to the ACE Sys Msgs Guide relates to: -
  The ACE does not support IP options. This IDS message is generated whenever the ACE detects IP options in a packet.
Am not interested in IDS or security features for my deployment scenario, just want LB functionality.
Definitely don't want these msgs flooding the logs
How do I turn off the IDS function on the ACE 4710 ?
TIA,
Sez
sez sharp Sun, 04/29/2012 - 08:14
Can not find any reference to IDS functionality on ACE 4710
To stop repeated messages clogging up log I had to disable logging for specific message, in this case: -
no logging message 400000
I would still be interested to know what IDS functionality is being refered to on these messages on ACE 4710
Sez
