How I can find the missing CDRs from the current inactive version.
Apr 26th, 2012
Dear All,
Before two days I have install and Upgrade call manager to 6.1.4.1000-10. Yesterday I have switch version and finish the upgrade.
Does anybody know how I can find the CDR that has been generated the period after the upgrade and before the switch version?
Thanks in advance
Gordon Ross Fri, 04/27/2012 - 00:26
  • Blue, 1500 points or more
Without doing a switch back to the previous version, I very much doubt you can.
In fact, all changes you've made to the system between installing the upgrade and switching versions will have been lost.
GTG
andrianna358 Fri, 04/27/2012 - 00:53
Yes Thanks fro the reply.
Do you know any other way regarding the CDRs ? If there is any other way to retrieve the cdrs logs from the other incative vesrion (partition) via a commands maybe?
Gordon Ross Fri, 04/27/2012 - 00:57
All the commands & APIs I've seen for talking to the CUCM DB only work on the active DB. (If you think about it, to access the inactive DB, you'd need to fire up a copy of the DB engine from the inactive partition too. It all gets horribly messy very quickly)
GTG
