vpn between asa and cisco 877 router
Apr 27th, 2012
hi,
i am trying to setup vpn between asa and cicso 877 router (in the pas i have setupo between asa and asa, pix and pix but not between asa and router)
I am confused with the nonat concept in cisco router (for vpn).  i mean why do you need a route-map and deny the traffic. could you throw some light on this ?
cisco link
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080a9a7a3.shtml#CLI1
Marcin Latosiewicz Fri, 04/27/2012 - 09:51
  • Cisco Employee,
Same as on ASA/PIX NAT is performed before encryption and after decryption.
How you will define traffic not to his NAT (or to hit it) is up to you, routing (VTI/GRE interface), access-list or route-map.
There is no concept of "no nat" on IOS routers.
M.
ROBERTO TACCON Fri, 04/27/2012 - 10:02
ip nat inside source route-map nonat interface FastEthernet0 overload
access-list 110 deny ip 10.20.10.0 0.0.0.255 10.10.10.0 0.0.0.255
access-list 110 permit ip 10.20.10.0 0.0.0.255 any
route-map nonat permit 10
match ip address 110
or better (if you have for example the IP public 1.2.3.5)
ip nat pool 1.2.3.5 1.2.3.5 1.2.3.5 prefix-length 30
ip nat inside source list nat-to-internet pool 1.2.3.5 overload
ip access-list extended nat-to-internet
deny   ip any any
Network Pro Sat, 04/28/2012 - 05:50
hi, thanks for this
what does this line do ?
