Link of Sample Configuration of APs in Design Zone
Apr 27th, 2012
I'm trying to find a document in Design Zone about configuring a Wireless AP and I wasn't able to find it. Can someone provide a link?
I have a good experience configuring switches, routers and firewalls in CLI and this is the first that I have my hands on APs (1240 AG).
Thanks in advance.
fbarboza Wed, 05/23/2012 - 13:25
Here is the link where you can check on the configuration guide for the access point you have.
http://www.cisco.com/en/US/partner/products/ps6521/prod_configuration_examples_list.html
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.4_10b_JA/configuration/guide/scg12410b.html
If you let me know what you want to achieve with the AP, I could try to provide you to steps to configure the AP as needed.
As basic information remember that the access points are layer 2 devices . To be able to configure the unit you need that the unit gets an IP address from the DHCP server on the network and you access the AP via the GUI or CLI using the IP address the DHCP server gave it or if not you can also configure an static IP address on the unit using the console port and assign the required IP address to the BVI1 interface.
