7204VXR (NPE400) GigaEthernet input error
Apr 27th, 2012
Hello Guys
I have a rather strange problem with a 7204VXR (NPE 400):  running a sh int giga 2/0 on the output see several inputs errors with the respective drops.
I have some losses on icmp packet.
The router si direct connect to Catalyst 6500
Any idea?
Many Thx
show int giga2/0
GigabitEthernet2/0 is up, line protocol is up
  Hardware is WISEMAN, address is 0011.215d.8d38 (bia 0011.215d.8d38)
  Description: *** Connet to CAT6500 ***
  Internet address is 192.168.10.1
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 8/255, rxload 16/255
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is SX
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:50:02
  Input queue: 0/4096/13584 (size/max/drops); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 62887000 bits/sec, 12101 packets/sec
  30 second output rate 31961000 bits/sec, 11122 packets/sec
     39481139 packets input, 26276227974 bytes, 0 no buffer
     Received 16746 broadcasts, 0 runts, 0 giants, 6574* throttles
    9214 input errors, 0 CRC, 0 frame, 203 overrun, 9011 ignored
     0 watchdog, 5746 multicast, 0 pause input
     37078384 packets output, 15407961165 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 0 pause output
show proc:
CPU utilization for five seconds: 64% / 60% one minute: 61% five minutes: 59%
sh version
Cisco 7204VXR (NPE400) processor (revision B) with 491520K/32768K bytes of memory.
Processor board ID 31652291
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
4 slot VXR midplane, Version 2.7
Last reset from power-on
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 500 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 400 bandwidth points
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
1 Gigabit Ethernet interface
1 ATM interface
125K bytes of NVRAM.
250880K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
show ip spd
Current mode: disabled.
Queue min/max thresholds: 4095/4096, Headroom: 2048, Extended Headroom: 4096
IP normal queue: 0, priority queue: 0.
SPD special drop mode: none
show buffers
Buffer elements:
     474 in free list (1119 max allowed)
     224292546 hits, 0 misses, 619 created
Public buffer pools:
Small buffers, 104 bytes (total 276, permanent 210, peak 360 @ 00:20:06):
     272 in free list (63 min, 273 max allowed)
     8710668 hits, 1157 misses, 634 trims, 700 created
     405 failures (0 no memory)
Middle buffers, 600 bytes (total 52, permanent 40, peak 73 @ 04:10:53):
     50 in free list (12 min, 52 max allowed)
     2051446 hits, 251 misses, 137 trims, 149 created
     155 failures (0 no memory)
Big buffers, 1536 bytes (total 74, permanent 50, peak 80 @ 02:24:04):
     73 in free list (5 min, 150 max allowed)
     252500 hits, 14 misses, 6 trims, 30 created
     0 failures (0 no memory)
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 100 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
     0 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 0, permanent 0):
     0 in free list (0 min, 4 max allowed)
Interface buffer pools:
Syslog ED Pool buffers, 600 bytes (total 150, permanent 150):
     118 in free list (150 min, 150 max allowed)
     5900 hits, 0 misses
IPC buffers, 4096 bytes (total 2, permanent 2):
     2 in free list (1 min, 8 max allowed)
     0 hits, 0 fallbacks, 0 trims, 0 created
Header pools:
Header buffers, 0 bytes (total 1255, permanent 256, peak 1255 @ 00:37:27):
     564 in free list (256 min, 1024 max allowed)
     254480 hits, 532 misses, 0 trims, 999 created
     256 max cache size, 41 in cache
     103935461 hits in cache, 254309 misses in cache
Particle Clones:
     1024 clones, 0 hits, 0 misses
Public particle pools:
F/S buffers, 128 bytes (total 512, permanent 512):
     0 in free list (0 min, 512 max allowed)
     512 hits, 0 misses, 0 trims, 0 created
     512 max cache size, 512 in cache
     0 hits in cache, 0 misses in cache
Normal buffers, 512 bytes (total 2048, permanent 2048):
     2048 in free list (1024 min, 4096 max allowed)
Private particle pools:
FastEthernet0/0 buffers, 512 bytes (total 400, permanent 400):
     0 in free list (0 min, 400 max allowed)
     400 hits, 0 fallbacks
     400 max cache size, 271 in cache
     129 hits in cache, 0 misses in cache
     14 buffer threshold, 0 threshold transitions
ATM1/0 buffers, 512 bytes (total 4000, permanent 4000):
     0 in free list (0 min, 4000 max allowed)
     4000 hits, 1 misses
GigabitEthernet2/0 buffers, 768 bytes (total 2000, permanent 2000):
     0 in free list (0 min, 2000 max allowed)
     2000 hits, 0 misses
     2000 max cache size, 32 in cache
     765911548 hits in cache, 599185 misses in cache
     14 buffer threshold, 908042 threshold transitions
Paolo Bevilacqua Fri, 04/27/2012 - 12:55
That is due to traffic bursts, the old NPE400 is too slow to keep up, causing interface throttling, packet ignored and overrun errors.
Alessandro Ball... Wed, 05/02/2012 - 01:47
Thanks for the answer Paolo
What they do not understand is why on another 7200 ( same configuration of hardware and software ) where I have the same volume of traffic is not reflected some losses.
Below the output:
  Hardware is WISEMAN, address is 0002.4a2b.5038 (bia 0002.4a2b.5038)
  Description: *** VERSO CAT 6500 ***
  Internet address is 62.97.32.1/24
     reliability 255/255, txload 7/255, rxload 24/255
  Full-duplex, 1000Mb/s, link type is autonegotiation, media type is LX
  Last clearing of "show interface" counters 1w1d
  Input queue: 0/75/505/0 (size/max/drops/flushes); Total output drops: 0
  30 second input rate 98024000 bits/sec, 15618 packets/sec
  30 second output rate 30298000 bits/sec, 13454 packets/sec
     4152728920 packets input, 3341128182222 bytes, 0 no buffer
     Received 3817019 broadcasts, 0 runts, 0 giants, 136 throttles
     742470 input errors, 0 CRC, 0 frame, 24596 overrun, 717874 ignored
     0 watchdog, 1474542 multicast, 0 pause input
     3622064099 packets output, 1479658168290 bytes, 0 underruns
     0 lost carrier, 0 no carrier, 22979 pause output
show ver
Cisco IOS Software, 7200 Software (C7200-JS-M), Version 12.4(13b), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 25-Apr-07 03:18 by prod_rel_team
ROM: System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
RACC_xDSL uptime is 45 weeks, 1 day, 2 hours, 31 minutes
System restarted at 08:12:01 METDST Tue Jun 21 2011
System image file is "disk0:c7200-js-mz.124-13b.bin"
Processor board ID 21268763
4 slot VXR midplane, Version 2.0
1 ATM interface
215040K bytes of ATA PCMCIA card at slot 0 (Sector size 512 bytes).
Paolo Bevilacqua Wed, 05/02/2012 - 11:07
It may look "same trattic", but it is not.
For that amount of traffic you need to upgrade. NPE-400 is 12 years old now.
Related Content
