Unable to hear Personal Greeting in Unity Connection
Apr 27th, 2012
Hi All,
We have a multisite architecture with centralised call processing and Unity Connection 8.x is also shared by all the sites.
Only in 1 particular site, we are unable to hear the personal greeting recorded by the users, it play the system default message. Can anyone please assist me on how to troubleshoot this problem.
Thanks in advance
Abraham
Rob Huffman Fri, 04/27/2012 - 12:43
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Abraham,
When you say "the system default message" do you mean the
"Hello - Cisco Unity Connection........"
Or
"Sorry xxxx is not available........"
Cheers!
Rob
Dan Bruhn @ CSC Rocks! :)
abraham1982 Mon, 04/30/2012 - 06:06
hI Rob,
Thanks a lot for your reply.
It is
I have changed the greetings to go to Personal recording still it is playing the System one and for all users at this site.
Abraham
jameskuder Fri, 11/13/2015 - 18:22
I am also having this issue in v10.5
I have changed it to play the personal greeting on the individual mailbox and it still will only play the default of "Sorry xxxx is not available........"
I am not sure on what else to try. I have removed the mailbox and re-created it several times. Same results
Rob Huffman Mon, 04/30/2012 - 06:28
  • Hall of Fame,
    Founding Member
Hi Abraham,
When you say that you changed the Greetings to use "My Personal Recording",
was this done at the Template level? If so, this will not be retroactive and will only
be applied to users created after the change was made. You may need to use
the Bulk Edit Tool to accomplish these changes for all the users at this site
Cheers!
Rob
"Everything is broken" - Bob Dylan
abraham1982 Mon, 04/30/2012 - 07:22
Hi Rob,
I have a couple of user extensions with their pin to test this. So I went into these user profiles in Unity and set the option inside the profile. I have not tried this on the template yet.
Related Content
