Wall mount bracket for AIR-ANT5160V-R
Answered Question
Apr 27th, 2012
Hi all,
I am looking for a wall mount bracket reference, for these 2 models of antennas :
- AIR-ANT5160V-R
- AIR-ANT2506
Something like that :
I was not able to find any reference in cisco product list. Does anyone have an idea ?
Thank you
Correct Answer by Scott Fella about 4 years 12 months ago
No its not part of there list... I though you already has these mounts.  I would just go buy it from another antenna manufature vendor... it will be cheaper:)
http://www.amazon.com/WLanParts-Antenna-Wall-Mount-Bracket/dp/tech-data/B002T0G8TQ
Overall Rating: 5 (1 ratings)
Scott Fella Sat, 04/28/2012 - 08:55
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You still can use that mount that you have in the picture... you just need to use the mounting strap or a u-bolt to mount the antenna to that particular mount that you are showing.  Make sense?
Sylvain Vasseur Sat, 04/28/2012 - 09:07
Hi Scott,
Thanks for your reply.
The picture I am showing is an example of what I have seen.
I am going to deploy lots of wireless sites, that's why I am looking for a reference of wall mount bracket I could buy to deploy easily the outdoor antennas.
It seems this accessory is not part of Cisco's product list ?
Correct Answer
Scott Fella Sat, 04/28/2012 - 09:10
  • Hall of Fame,
    2017 Wireless
Sylvain Vasseur Sat, 04/28/2012 - 09:55
Thank you, I have to check if the diameter is correct. But yes, it wil be cheaper !
Scott Fella Sat, 04/28/2012 - 10:04
  • Hall of Fame,
    2017 Wireless
There was another company when I googled antenna mounting bracket that sold that mount for 6 dollars.
Scott Fella
Sent from my iPhone
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
