RV220W. WLAN <-> LAN problems
Answered Question
Apr 27th, 2012
I recently bougt this router for its great throughput and VLAN capabilities. It replaced a standard Linksys DIR-655
But now I am having trouble connecting my Samsung Galaxy2 (Android 4.0.3) telephone to my computer. Telephone is connected to wi-fi and computer is connected to wired  LAN.
When starting Kies on my telephone (this is a webserver app) it tells me to connect to http://192.168.1.202:8080/  on my computer. This is the correct IP address for the telephone (I have reserved it on the router)  and firewall is OFF in windows 7.  But there is no response with firefox or IE8.   I have not changed anything on either the computer or the telephone since I replaced the router, so the problem must somehow be linked to the router.
Both telephone and computer are connected to the internet OK.  I can even remote control the computer from the telephone using the VNC app on the telephone!So the network IS working. The problem is only related to the communication with the Kies app.
Anybody who might know what is going on?
Correct Answer by blwright about 4 years 9 months ago
Armand,
unfortunately if the network IS working then there is nothing more that can be done from a Cisco SBSC support standpoint. However, I found a link that I think may help. Please keep in mind that any changes made as result of information found in this post will be done at your own free will.
http://androidforums.com/samsung-galaxy-s2-international/359070-trouble-kies-air.html
Hope this Helps
Blake Wright
Cisco SBSC Network Engineer
Overall Rating: 5 (1 ratings)
Correct Answer
blwright Thu, 05/03/2012 - 18:05
Armand,
Hope this Helps
Blake Wright
ArmandAanekre Sun, 05/06/2012 - 01:46
Thank you for your response. The problem is gone. I dont know why, but it could be related to that my Kies software has been updated.  My worry was that there was some kind of blocking between WLAN and LAN.
Armand
Related Content
