"pool-member" command missing in vpdn-group for ios 15?
Apr 27th, 2012
Hi guys,
     We have noticed the 'pool-member' command that is used in the 'vpdn-group' (when command 'request-dialin' is used) is no longer available in ios 15.  It is available in ios 12.  It it used to link a dialer to the vpdn-group.  Was it moved elsewhere or is there a different way to link the dialer to the vpdn-group?
Thanks.
Jason
daniel.messana@... Sun, 02/09/2014 - 20:24
Is there any updates on this post?  i am having an issue with this as well while trying to config using the following sample at http://forum.strongvpn.com/forums/topic/12/l2tp-ipsec-with-cisco-ios
service internal
no ip source-route
no ip gratuitous-arps
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 10.10.10.127 10.10.10.254
ip dhcp pool LAN
import all
network 10.10.10.0 255.255.255.0
domain-name local
dns-server 10.10.10.1
default-router 10.10.10.1
ip cef
ip domain name local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip multicast-routing
no ipv6 cef
vpdn enable
vpdn-group L2TP-STRONGVPN
request-dialin
protocol l2tp
pool-member 2
initiate-to ip 66.151.32.12
no l2tp tunnel authentication
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key *********** address 66.151.32.12
crypto ipsec transform-set ESP-AES256-SHA esp-aes 256 esp-sha-hmac
mode transport
crypto map STRONGVPN 10 ipsec-isakmp
set peer 66.151.32.12
set transform-set ESP-AES256-SHA
match address L2TP-SA-DIALER0
track 1 interface Dialer0 ip routing
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
no atm ilmi-keepalive
dsl bitswap both
interface ATM0.1 point-to-point
description $ES_WAN$$FW_OUTSIDE$
ip flow ingress
pvc 1/32
pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache cef
no ip route-cache
ip policy route-map MAP-INTERNET
interface Dialer0
ip address negotiated
ip mtu 1492
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname ********
ppp chap password 7 *********
ppp pap sent-username ******* password 7 ***********
interface Dialer1
description VPN (StrongVPN)
ip mtu 1400
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1360
dialer pool 2
dialer idle-timeout 0
dialer string 123
dialer vpdn
dialer-group 2
no cdp enable
ppp chap password 7 *************
ip route 0.0.0.0 0.0.0.0 Dialer0
ip dns server
ip nat inside source route-map MAP-NAT-DSL1 interface Dialer0 overload
ip nat inside source route-map MAP-NAT-VPN1 interface Dialer1 overload
ip access-list extended L2TP-SA-DIALER0
permit udp host 188.96.77.237 host 66.151.32.12 eq 1701
access-list 1 permit 10.0.0.0 0.255.255.255
access-list 2 permit 10.10.10.0 0.0.0.127
access-list 3 permit 10.10.10.128 0.0.0.127
access-list 101 permit ip 10.10.10.0 0.0.0.127 host 208.75.79.17
access-list 101 permit ip 10.10.10.0 0.0.0.127 host 208.75.76.17
! ... and lots of other ips
access-list 199 permit ip any any
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
no cdp run
route-map MAP-INTERNET permit 10
match ip address 101
set interface Dialer1
route-map MAP-INTERNET permit 98
match ip address 3
route-map MAP-INTERNET permit 99
match ip address 1
set interface Dialer0
route-map MAP-NAT-DSL1 permit 10
match ip address 1
match interface Dialer0
route-map MAP-NAT-VPN1 permit 10
match ip address 1
match interface Dialer1
event manager applet dialer0-up
event track 1 state up
action 001 cli command "enable"
action 100 cli command "show ip interface brief | include Dialer0"
action 101 regexp " [0-9.]+ " "$_cli_result" ip
action 200 cli command "conf t"
action 201 cli command "ip access-list extended L2TP-SA-DIALER0"
action 202 cli command "no 10"
action 203 cli command "10 permit udp host $ip host 66.151.32.12 eq 1701"
action 204 cli command "exit"
action 210 cli command "interface Dialer1"
action 211 cli command "no shutdown"
action 212 cli command "exit"
action 299 cli command "exit"
event manager applet dialer0-down
event track 1 state down
action 100 cli command "conf t"
action 101 cli command "interface Dialer1"
action 102 cli command "shutdown"
action 103 cli command "exit"
action 199 cli command "exit"
action 200 cli command "clear l2tp all" pattern "[confirm]"
action 201 cli command "confirm"
action 202 cli command "clear crypto session"
action 203 cli command "clear crypto sa"
alexvoronovitsky Fri, 04/04/2014 - 02:31
I have the same problem,
How do I make a specific dialer interface to go through a specific vpdn-group (l2tp request-dialin connection) ?
Is there any replacement configuration for this?
Thanks.
Related Content
