SSL VPN options on 8941
Answered Question
Apr 27th, 2012
Hi All
Documentation seems to suggest that SSL VPN is not supported on the 8941. Is this correct, seems strange that all other handsets are supported.
Correct Answer by Gordon Ross about 4 years 11 months ago
The 8941 is a low(er) cost video enabled handset. Some features just aren't there.
GTG
Overall Rating: 5 (1 ratings)
Correct Answer
Gordon Ross Fri, 04/27/2012 - 22:24
  • Blue, 1500 points or more
GTG
esa786_2 Mon, 01/20/2014 - 01:55
Do we need CUCM 9.X for using VPN connection for cisco phone 8941 ?  please let me know.
Chi Fai Leung Wed, 06/25/2014 - 05:13
CUCM 9.X --- ASA ----ssl vpn ---- 8941
I tested the SSL VPN on the 8941, that is fail.
On my 7942, that is working ...
